Pilot Foglights in GA
Chevycobb
10-22-2003, 04:08 PM
Does anyone live near the marietta/kennesaw area in Georgia who knows where I may be able to get a set of the Pilot Foglights for the LT1? I tried Advanced, but they said they are going more with APC products now, so they don't carry them...couldn't even find it in the system, plus the Pilot set looks to fit better anyway. Pepboys was out of them too, and I didn't see any at autozone.
I just got done putting in a set of 9005's and 9006's and so I need to upgrade the fogs to match them, but I want something that would be fairly cheap and easy to do, and the Pilots seems to be the best I can find(or not find)
xxsaint69x
10-22-2003, 11:09 PM
have u tried walmart? or you can try some ricer/audio shops. They usualy cary them.
Marcin
94BlackBowtie
10-23-2003, 07:46 AM
Like Marcin said - try Wal-Mart - they carry Pilot's, just don't know if they will carry the style you are looking for.
Are you going for the kind in my sig? If so, I may be able to help you out - I have a used set.
Chevycobb
10-23-2003, 05:14 PM
I was trying to find some like these (http://www.pilotautomotive.com/pilot2bb.htm) with the clear lens. I guess I would have to order them beause they seem to be only for the camaro, but i'll try walmart.
94BlackBowtie
10-24-2003, 08:55 AM
Originally posted by Chevycobb
I was trying to find some like these (http://www.pilotautomotive.com/pilot2bb.htm) with the clear lens. I guess I would have to order them beause they seem to be only for the camaro, but i'll try walmart. Yes, those you would have to order. I don't know why they say they are specifically for the Camaro - but if you order them - please let us know.
Chevycobb
10-24-2003, 02:57 PM
Probably because it uses the existing wiring.
94BlackBowtie
10-25-2003, 07:33 AM
Probably because it uses the existing wiring. See - that's what I can't figure out. In order for it to use the existing wiring it would A - either have to splice into it like my setup - or B - come with some sort of adapter to go from 885 to H3 bulbs. :confused:
My first guess would be that they used the stock fog mounting brackets - and if that is the case - they should look very nice.
Also - any two wire fog light system (one hot one ground) will use the existing wiring.
Chevycobb
10-25-2003, 12:17 PM
Hmmm...I wish someone else had these that could tell us, maybe i'll make a new post asking about them
