toddfather
10-21-2003, 09:25 PM
Here is the problem.When I make sharp turns at low speed or back up and turn,I hear this god awful squeel noice and grinding noise from the back end.Sounds like fingers in a fan blade kind of.I have heard many a rumor of rear ends in Z-28 not lasting to long.Here is a little history on the car.I have beefed up engine quite a bit,have aftermarket wheel and larger tire(made noise before,just not as much).Has 80k on origonal motor and tranny.I also drive like it is the last day I will ever have it,which at my present pace not very long.If it is the differential what is a good one to replace it with?Same for the axels?
Also recently had transmission oil changed and a tranny cooler installed,now under W.O.T. tranny holds first gear and slips going into second.All other shifts are fine.Fluid is full not overfilled or anything.
