FASTFATBOY
10-21-2003, 09:05 PM
I have a Big ass cooler, a yank 3500 converter and theses parts internally
Alto red clutches with Kolene steels
Raybestos blue plate overdrive clutch set
hardened input shaft, front drum,reaction shell and roller bearing
(PATC torque drive kit)
29 element sprag
front and rear 5 pinion planetaries
corvette servo
13 vane front pump
1-2 accum spring
heavy duty pump slide spring
Raybestos Kevlar band
Hardened pump rings
"The Beast" sun shell
Shift improver kit
Do I need to back up and get a Turbo 350? I want this to be a TRUE street car, It will be cruised with A/C and a 4.10 or better gear and will be raced.
David
29 element sprag
corvette servo
13 vane front pump
1-2 accum spring
Hardened pump rings
Shift improver kit
David
