Do the C5 rotors warp as bad as the Fbodies?
ZDriver96
10-20-2003, 10:21 PM
Getting ready to do a c5 conversion and figuring out if stock or stockish rotors will withstand the dual pistons...
I tested out my LS1's at 145mph down to 50mph and warped them pretty good.
So instead of just getting new rotors... im thinking ill do another brake upgrade...
Slappy3243
10-20-2003, 10:27 PM
145 down to 50 MPH is going to be harsh on any stock rotor no? You probably have to get some serious brakes if you will be doing that often. I would go with the upgrade if I were you.
ZDriver96
10-20-2003, 10:39 PM
i rarely go up that fast... But If i do for some reason I want the brakes to be up to the challenge. The LS1 calipers gripped good but warped the rotors in the process.
whoa guy
10-20-2003, 11:40 PM
Why did u do that?
jasons93z
10-21-2003, 12:14 AM
There is no reason to be going that fast in the 1st place, then slamming on the brakes. Im not saying i have not gone up there, just dont do it often. You will either get killed, or arrested. For your question, some slotted rotors from jegs would work fine:)
