Will i pass emissions in IL with.........
stang_killa94
10-11-2003, 01:18 AM
jet hot long tube headers, cat, and flowmaster muffler?
chesee48
10-12-2003, 01:15 PM
jet hot LT's require the cat to be moved and be removed. So techincally, you cant have the set up, jet hot LT's with also a cat thats in the right spot, in order to pass emmisions. FLP's have a LT that'll pass, but its like 1200
wrencher
10-12-2003, 01:46 PM
Is that the only mod's?
With a good quality catalytic converter,you should pass.
If it is one of those "catco" hi flows I have seen lots of problems with them & emission testing.
I do alot of cars for the Ill. IM-240, & seen alot.
Take it in & see what it will do.
B-4 test , in the lane inform the "inspector" you request a Pre-condition.
They will run it up on the dyno b-4 testing it.
This makes sure the converter is lit & you get the best # possible.:D
89'Formula
10-12-2003, 09:15 PM
you will pass no prob unless you have a bad cat. converter, if u don't run racing fuel through it ever then it should be fine, and like he said make sure you get the converter nice and hot
