TPIS Miniram/Fuel Rails/Injectors/52mmTB/Sensors
TPIS Miniram II intake, fuel rails, FMS #24 Injectors, 52mm TPIS TB, TPIS air foil, MAP sensor, TPS sensor, and IAC valve. This intake was removed from a 1990 L98 but will fit most SBC engines. This intake ---WILL NOT--- work on LT1 or vortec engines.
New these parts would cost: $900 Intake, $350 Fuel Rails, $280 Throttle Body + core, $220 Injectors, $50 Air Foil. Total would be $1800 + sensor costs.
I am asking $1000 + shipping for everything.
My post counts on corvetteforum.com or hybridz.org under thepenguin99 are higher than here. I do not usually post here because I don't have a camaro.
I am located in Memphis TN. If I stated a mileage number for the throttle body I would be lieing to you. It looks to be in good shape, was working perfectly, and I can shoot you a pic if you want.
