Parting out 79 Trans Am
Old Oct 6, 2003 | 10:36 PM
jp2002ls1's Avatar
I'm parting out a 79 Trans Am. There are a lot of miscellaneous parts on the car that are good so if you need anything just let me know. Here is a list of some of the main parts for sale:
B&M Megashifter
Dynotech 3 1/2" aluminum driveshaft
Pontiac 400. Has #62 heads. Comp Cams 292-h cam.
Comp cams hyd lifters, Comp cams roller tip rockers,
trw forged pistons, stock crank/rods.
Edelbrock single plane intake.
TH-400 trans, needs a rebuild,
trans crossmember
The whole front suspension is good, front nose, glass, dash, stock gauges,etc
I could cut the 6 pt. roll cage out if anyone wanted it.
If anyone is interested in anything just drop me a reasonable offer.
Email: JP2002LS1@aol.com
Old Oct 6, 2003 | 10:45 PM
jp2002ls1's Avatar
Most the parts are in good shape, the engine did have some coolant leak into the oil, not sure where from so the engine would need to be torn apart, or I'll part it out.
Old Oct 7, 2003 | 03:44 PM
Freak's Avatar
i need a pass side trunk hinge, and a heater/AC box. you got either? how much you want for them?
Also need the washer bottle and radiator overflow tank and possibly a radiator. but they arent as urgent.
do you have the shaker scoop?
how bout rims and tires?
cant think of anythign else as the moment, but im sure otehr things will pop up..
thanks
Troy
Old Oct 7, 2003 | 06:08 PM
MEAN_SBC's Avatar
Do you have pics???? I'm currently working on a 78 firebird project, and I could use some pieces...
Old Oct 7, 2003 | 06:42 PM
jp2002ls1's Avatar
The trunk lid is in excellent shape, I think the hinges are in excellent shape as well. $10 for the hinge if you come pick it up.
Most the parts you mentioned, heater, radiator are already gone. The rims are convo pros (skinnies) on the front in excellent condition, old cragar's on the rear. It does have the shaker hood if you want the scoop I think it comes off. The gauge cluster with tach and intstruments are excellent and there are many other good parts on the car, just let me know what else you guys need, I'll sell it all real cheap so I can take the rest of the car to the junk yard.
thanks
Troy
Old Oct 7, 2003 | 07:17 PM
Freak's Avatar
i should be able to come out there, but i work swing shift, so it might be a week or so, are you planning on keeping it that long? I MIGHT be able to get out tommorow, but I dont knwo yet, have plans, and not sure when Ill be done...
i am still trying to figure out how to get to the hinge anyway.
the scoop should come right off, unless it has been epoxied to the hood or something. how much you want for it?
does it have the deluxe interior? or the standard? what color is it?
if you still have it when i am able to come out there, ill see if there is anythign else I can use...
thanks
Troy
Old Oct 7, 2003 | 08:03 PM
jp2002ls1's Avatar
I plan on getting rid of the car this weekend. I will take off the hood scoop and hinge tommorrow and make sure the hood scoop is good. Most the interior is gone, I am waiting on someone else who is taking the steering wheel, possibly the dash and door panels which aren't that great. It does have the seatbelts still in it, I'm not sure how those are, it has a Simpson 5 point harness on the drivers side also.
Old Oct 7, 2003 | 08:47 PM
RoadRnnr69's Avatar
Do you still have the wheels? Are there any seats?
I may be interested in the roll bar, how much?
Old Oct 7, 2003 | 09:01 PM
jp2002ls1's Avatar
I still have all the wheels, I have the two front seats (stock), the seats are kind of dirty. The rollcage could also come out. Anybody is welcome to come by and see it. Make me a reasonable offer on the stuff and we will go from there.
Old Oct 9, 2003 | 03:28 PM
406TA's Avatar
JP, do you have the two grilles that are on the lower part of the nose (D/S & P/S)?? Thanks.
Gary
Old Oct 10, 2003 | 01:59 AM
Freak's Avatar
dont throw away/mangle the metal cylinder pin thing away. I need that with the hinge.
Old Oct 10, 2003 | 09:12 AM
jp2002ls1's Avatar
Gary, I have the front grills but I don't think they are worth using because they have some sun cracks on them.
Troy, I have the hinge and hood scoop, just give me a call if you want to come look them over and call me so we can decide on a price. (248) 921-6421 John.
Old Oct 11, 2003 | 12:02 PM
Freak's Avatar
sounds good, I am on afternoons untill wed, so Ill get ahold of you this week. what is a good time to call?
Old Oct 11, 2003 | 09:54 PM
jp2002ls1's Avatar
FREAK, you can call me whenever, I work or have school during the days, if I don't answer just leave a voicemail and I'll call you back. Sunday I have class 1-6 in the afternoon.
Old Oct 12, 2003 | 06:56 PM
DougJ's Avatar
how bout 100 for the front wheels and the driveshaft, ?
DJ
