jp2002ls1
10-06-2003, 11:31 PM
I trailered this car over to my house and it doesn't look like it would be feasible to fix it up so I'm parting it out.
79 Trans Am
There are a lot of miscellaneous parts on the car that are good so if you need anything just let me know. Here is a list of some of the main parts for sale:
B&M Megashifter
Dynotech 3 1/2" aluminum driveshaft
Pontiac 400. Has #62 heads. Comp Cams 292-h cam.
Comp cams hyd lifters, Comp cams roller tip rockers,
trw forged pistons, stock crank/rods, coolant leaked into the oil so it probably needs work.
Edelbrock single plane intake.
TH-400 trans, needs a rebuild,
trans crossmember
The whole front suspension is good, glass, dash, stock gauges,etc
I could cut the 6 pt. roll cage out if anyone wanted it.
If anyone is interested in anything just drop me a reasonable offer. Email: JP2002LS1@aol.com
79 Trans Am
B&M Megashifter
trans crossmember
