Best first suspension mod?
kgkern01
10-06-2003, 11:53 AM
I was thinking
1. 35mm/21mm sway bars
2. DD SFC
3. 550# springs/ground control/Re-valved Bilstiens
4. STB
5. Rear end components (PHB, LCA, etc)?
Is this the best order to go in when upgrading the suspension? Is a daily driver and plan on doing some autocross next year. I will be in SM class anyway, because I will doing 4.10's this winter.
LPEdave
10-06-2003, 02:28 PM
I'd do it more like:
1. Tires
2. Springs/Shocks
3. Sway Bars
4. SFC
5. Rear end stuff
Tires are your biggest suspension benefit. STB is probably optional, or after all the above. Sway bars I'd decide on what to use after you feel what the tires, springs and shocks are doing right or wrong. SFC, unless you've got a convertible, could probably wait a bit.
Dave
V6Bob
10-08-2003, 01:29 AM
Depends on whether you're looking for quick thrills by doing the things you'll feel most first, or a logical plan to setup your car, given where you want to end up.
The logical plan is to first stiffen the chassis (sfc, stb) then stiffen the suspension bits (phr, lca), then do the mods that are not easily tweaked (springs, shocks). Then tires, and finally tune the car with the sways. You may be making a different choice there when you see how the car handles, and they're the way to tune the chassis you've built up.
1LEThumper
10-08-2003, 03:23 AM
I kept stock 1LE stuff on the car for oh probably 6 years....then put a set of KB DD on it. Then it stayed that way for another couple years....learned my lesson on solid LCA's. Put on some rod end'd LCA's and panhard rod.
then it all just went to hell and I changed everything. :D
bruecksteve
10-08-2003, 10:37 AM
Suspension wise:
1. Sway Bars
2. Springs/Shocks
3. PHR
4. Bushings
5. T2R Diff
6. Torque Arm
7. SFC
8. LCA
9. STB
Tires are a big variable depending on what you'll be doing. You'll probably need 2 sets, one for street, one for autocross.
LT4Firehawk
10-08-2003, 11:45 AM
The absolutely best first mod would be tires. I would recommend the Nitto 555R II, I've used them on several of my cars and love them. Also, you can use them as a street tire too, just realize that they have a short life for a street tire (up to 15K for street only, less when combined with track use), and once they are down to the wear bars the wet traction starts to go away. After the tires, it really depends on how far you want to go with your car. In general though, I'd agree with stiffening the chasis first (subframes, stb) so the suspension can work to its full potential, then start on the suspension itself (springs, sway bars, etc).
robvas
10-08-2003, 11:48 AM
15K out of 555R's on the street would be a miracle. Many guys don't get that with regular tires. I got about 5,000 out of mine and they're still good but you can't use them in the rain anymore.
LT4Firehawk
10-08-2003, 11:53 AM
Yeah, that is on the high side, but it is doable. :D The main thing with mileage on the 555R IIs is if you use them for autox/roadcourse at all, if you do they wear a lot quicker. For just street use they will last a good while if they are treated and maintained well.
stereomandan
10-09-2003, 09:14 AM
I'm surprised any of you are recommending anything before the sub frame connectors.
First, stiffen up your chassis. If you do other mods before that, and get the suspension stiffened up and not the chassis, you may loosen up the chassis more than necessary. Get the sub frame connectors on there before you loosen up the chassis to the point you can't get it tight again.
I did Bilsteins before the SFCs, but that's because I thought I had as bad front shock. I just ordered my sub frame connectors and should have them installed in a couple of weeks. For $150, they are the best insurance to have before you start doing a bunch of suspension mods.
Just my opinion.
Dan
bruecksteve
10-09-2003, 09:37 AM
I'll say it again. SFC's only make minor changes to your handling. You want to effect your handling, make suspension changes. You want to get rid of every last wiggle or shake, add SFC's. First, they're illegal in stock or street prepared classes. I know guys running stock that will run circles around people with SFC's.
I'm not saying that SFC's don't make a difference, I know they do. but I'll guarantee, take two cars with identical mods but the only difference is SFC's, there will be no quantifiable difference in autocross times.
These cars aren't as bad (in terms of stiffness) as you all are giving them credit for. Sure, convertables can use more stiffness than the rest, but.... And yes, I use a STB but I can't feel any difference there either. I just use it because I need to do everything allowed within the rules. Could it make a .1 of a second difference, maybe. Sort of like LCA's. If seen test that point to .1 second or so in 60ft times but at what cost?? Money and harsher ride.
Spend your money where you can measure and FEEL a difference first. Go back later and add the rest.
stereomandan
10-09-2003, 10:05 AM
Steve,
I agree with you 100%, except for what to do first.
The SFC's are more for insurance than handling. I want them on my car because I plan to keep it indefinately. I want the chassis to stay rigid, and not develop squeeks and rattles early. SFC's are not a suspension mod at all in my opinion, they are a chassis mod, designed to let the vehicle handle the abuse the upgraded suspension will throw at it.
If you are strictly talking autocross, in a class where SFC's are prohibited, than that makes your decision right there. Don't use them, but for ANY class that allows them, it would be my first mod. Not from the standpoint of getting better times, or better handling, but to keep the car in better shape over time. That's all.
I think we are just looking at it from two different perspectives. Me, a daily driver who wants better handling and a durable chassis, and you, a driver that also is heavy into autox.
Dan
bruecksteve
10-09-2003, 10:09 AM
So far, the only thing that rattles on mine is the panhard rod (rod ends) and my cat (shot). My car has 153,000 miles on it and has no rattles at all!
stereomandan
10-09-2003, 10:24 AM
I'm glad to hear it. You have more experience in suspension mods and autox than I do, so I defer to your knowledge, but like I said, to me, they are insurance, and well worth the small price.
I know they are not necessary, and I had to wrestle with myself to buy them before I upgrade my swaybars, but I think I made the right choice to get the SFC's first, if for nothing other than piece of mind. Others have noticed a big difference when they were installed, but maybe that's because their chassis was beat up. I know mine is in great shape, and I want to keep it that way, hence, my decision to buy SFC's first.
Dan
Lady in Nomex
10-09-2003, 01:11 PM
I like to steer people towards getting SFCs right away. You can show yourself why this is an important mod easily by doing the following before and after you get SFCs. Find the worst railroad track crossing in your area and drive over it at speed. What happens without SFCs is the car wants to hunt around and it will take some steering input to get the car going straight again. Try this with SFCs and you should not have to struggle for control. Pretty kewl!:D
bruecksteve
10-09-2003, 01:15 PM
Once again, it depends on what they're going to do with their car. Without knowing that you might be steering them in the wrong direction.
Also, try the train track thing with original shocks and good shocks and see the difference.
Lady in Nomex
10-09-2003, 01:33 PM
I'll stick by my guns here. ;) SFCs make a difference in rough road handling, and help with those rattles that will develop without SFCs. If folks are going to drive the car in a manner that pushes it (all of us here fit that description) those rattles will develop quicker, so SFCs are a win-win first mod. After the SFCs are installed, then you can merrily go about installing other handling mods with the maximum benefit. Eliminating a good deal of unibody flex by installing SFCs is a big positive in the whole handling equation. There is a trickle down effect.
bruecksteve
10-09-2003, 01:47 PM
And I'll stick to mine. Find out what they're going to do with the car first... Making someone illegal won't score any points for you. And, it's not a suspension mod which is what the original question was.
Lady in Nomex
10-09-2003, 02:12 PM
As far as SCCA, sure, I agree with you, you don't want to make an illegal recommendation. I am having a hard time with SFCs not being a handling mod tho, so we'll just have to agree to disagree. SFCs are not part of the suspension, agreed. ;)
V6Bob
10-09-2003, 06:30 PM
The original poster said he was going into SM, where some types of sfcs are legal, although perhaps not the DDs.
I've never understood that one exactly. People say the rule is the sfcs cannot meet. The DDs go to the center of the car, but there is a gap between them.
Also, the original poster included them in his list of "suspension mods". It's not precise language, but conceptually bracing the chassis helps the suspension work better.
Lady in Nomex
10-09-2003, 07:08 PM
Thanks for your clarification Bob! I have the KB DD SFCs on my '97 TA. I noticed a difference just going down the driveway of the shop that welded them on! I also have a race car 3rd gen f-bod which always had a welded cage. I just got the Global West front to back SFCs for this season and the car handles even better! The standard line is with a welded cage you don't need them. I was encouraged by my fellow racers to get the SFCs and I am very happy I did, read on.
I broke an axle on the race car at over 100mph and the combination of my Alan Blaine cagework and SFCs surely saved the car. There was a big gash on the RH SFC and that would have been torn up subframe otherwise. My passenger's side floorpan is still buckled a bit! :eek:
Not many folks think of SFCs as a safety feature!
kgkern01
10-09-2003, 11:59 PM
So I'm looking at subframes, then coil-overs, then go from there? This is my daily driver, but I do plan on trying to run in a few autocross events next year and will have 4.10's and torsen by then, so I will be in SM anyways.
kgkern01
10-10-2003, 12:00 AM
By the way, Lady in Nomex, how exactly would I go about cambering my 10-bolt correctly? May be able to get access to a welder.
Lady in Nomex
10-10-2003, 12:11 AM
KG, I would not do this myself. Take it to someone who has done it before. I took it to Matt Adams VSE in Carmel Valley, CA. I have another friend who races CMC in an F-body. He has his own machine shop and is afraid to tackle this one! If you are in the San Fran Bay Area I could point you to some shops.
V6Bob
10-10-2003, 12:37 AM
"So I'm looking at subframes"
As I said, I'm not at all sure the DDs are legal in SM. If you care about being competitive in autocross your _first_ step is to get the rule book for the events you want to run.
"then coil-overs, then go from there? "
See my post above for an alternative plan. Changes for the first mods suggested there will be subtle, but if you're going to go all the way anyway...
bruecksteve
10-10-2003, 08:54 AM
SCCA SM rules for SFC's are:
Subframe connectors are allowed, but each connector must be attached individually without any lateral components attaching the two longitudinal frame rails. Subframe connectors may be bolted or welded
DD's are not allowed nor are any the cross to each frame rail.
V6Bob
10-10-2003, 10:56 AM
Steve - thanks.
The part I don't get is "lateral components attaching the two longitudinal frame rails". A lawyer (SCCA has plenty) would tell you that means longitudinal components that don't attach the _two_ longitudinal frame rails are OK. Since the DDs don't attach to each other????
Or do they say "attach" means to the car and not each other?
It's confusing and ambiguous.
bruecksteve
10-10-2003, 11:04 AM
You can connect the front subframe on the left to the rear frame on the left and the same for the right. The connectors can't cross left to right and visa versa.
V6Bob
10-10-2003, 11:42 AM
Steve - I understand what you're saying. The problem is that's not what the rule says.
What you're saying could have been said "without any lateral components attaching the longitudinal frame rails". The legal deal is that when the "two" is added in there the assumption is that it is meant to be used. The DDs do not attach to each other.
Someone could give SCCA a hard time about this one. When I was roadracing there were more picky disputes about rules than this. Any rallyist would jump all over it. Of course, SCCA could then just reword the rule.
bruecksteve
10-10-2003, 01:03 PM
If anyone would like to disagree with the SCCA SEB can join the Evolution discussion forum
evolution-discussions@yahoogroups.com or go to the SCCAforums.com message board. I don't make 'um, just have to follow them.
kgkern01
10-10-2003, 04:06 PM
Lady in Nomex - If it is that difficult of a job to camber a 10-bolt, I'll probably skip that, especially since I am in Louisville, KY, no where near CA.
Regarding the DD subframes, I will probably go ahead and get those first, then coil-overs (probably straight rate springs w/re-valved Bilstiens), then go from there. It is my daily driver and won't be competing in autocross but just for fun at first anyway.
Regarding the DD subframe rule, I would have to say that the way that it is worded would imply that you cannot tie only the "lateral" subframes together meaning as long as the two subframes are separated by something (center tunnel) that you would NOT be tying them together. This isnt going against you brueksteve, we know that you just follow what your area SCCA says, I would definitely dispute it here if it was brought up as an issue though. My dad's neighbor is an SCCA instructor, maybe I'll talk to him about the subframes.
