350 HRSS
10-02-2003, 01:08 PM
:death: to the IAT sensor and grommet in the stock lid!
How did yall get them out when you switched over to a aftermarket lid? I tried to pull it out w/ needle nose pliers (one the SIDES of it), and it will barely budge.
I liked to never got the dang MAF out of it, that took heat!
Thanks!
NEWBIE T/A
10-02-2003, 01:27 PM
Sprayed it liberally, let it sit, and then finagled w/ it 'til it finally came out.
I also :think: think that I used a little bitty screwdriver to coax it
out - seems like the grommet came out w/ the sensor.
I do remember that MAF being a real beotch !!
:eek:
I used anti-seize on it when I put the lid on - a little messy, but it sure comes off easy ! :D
Good Luck !
Britt
P.S. - Didja check
http://www.installuniversity.com/install_university/installu_pages/freshman_year/whisperlid_install.htm for tips ?
350 HRSS
10-02-2003, 01:40 PM
Good Luck !
Britt
P.S. - Didja check
Thanks for the info!!! I am going to try to work w/ it as best as I can :D
350 HRSS
10-02-2003, 01:56 PM
HAHAHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!
I GOT IT OUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Pushed it from the inside!
That IAT sensor and grommet just got :Owned:
:thumb:
:D
96SFLZ
10-02-2003, 01:59 PM
:thumb: That's just what I was going to tell you to do. Push with one hand, pull with the other.
NEWBIE T/A
10-02-2003, 02:05 PM
:thumb:
:D
Congrats !!
Britt
