Turn signal lights
SP99SS
10-02-2003, 11:39 AM
Anybody ever change out a front turn signal bulb?
One of mine went out last night and I haven't looked at it yet to see how easy/difficult it is to change.
Can I change just the bulb or do I need to replace the whole unit?
Thanks,
SP
Jilly
10-02-2003, 12:53 PM
Just change the bulb. It's really not hard but it's easier if you have skinny arms. :)
camaro322hp
10-02-2003, 06:28 PM
Thanks,
SP
pretty easy. you'll see a "door" under the car directly under the lights. remove the bolts holding the "door" closed and swing it open and you're at the back of the housing. the "door" is actually more like a plastic flap. you'll know what i mean when you get under the car.
99blackSS
10-02-2003, 06:46 PM
Just the bulb, its pretty simple, very hard to do from the top.
Stumper66
10-02-2003, 11:19 PM
Don't listen to them. It's easy to get to from the top, tough from the bottom.
Just get a 10mm socket, undo the one bolt that holds in the headlight, slide it out and you have easy access.
mPoRtSsUcK
10-03-2003, 12:48 AM
Exactly what I was going to say. Pop the headlight out and you've got easier access than you could ever have going from the bottom.
Edit: Whoa, gotta change that sig. GOt rid of that car over a year ago!
camaro322hp
10-03-2003, 02:05 AM
hmmm... wasn't that tough from the bottom. unless you consider about 60 seconds tough...
