last weekend I ran my car at Lapeer Dragway in Michigan, I had never raced at the strip before.
I had a best time of 13.447 @104, backed up by a 13.474@104 & 13.528@ 105. The car is stock other than a K&N and the free ram air mod. I would like to get it into the 12's without draining my pocketbook. Even as we speak my cousin is trying all he can do to beat me in his Mustang, because I embarassed him at the track. What are some suggestions?
95GRNZ 10-02-2003, 10:39 AM What car do you have? Year? A4? M6? Bit more info, please.
95GRNZ 10-02-2003, 11:04 AM It is pretty easy to get your car to 12's.
Here's what you need: lid, cutout/catback, higher stall and sticky tires.
Maybe not even all of them. Add some LT's and you;ll have no problem. ;)
I'm sure other guys will pitch in w/more suggestions.
TS
I want the car to look and sound stock on the street, is it still possible?
Teal94Z 10-02-2003, 11:14 AM Lid, SLP Dual Dual, it will sound stock, and just might get you there
95GRNZ 10-02-2003, 11:16 AM Originally posted by Teal94Z
Add a higher stall and sticky tires and it's done. Sounds and looks pretty much stock.
BigZ28 10-02-2003, 11:24 AM A lid, converter and some tires should get you into the 12's pretty easily. We have our lids on special righ now for $99. I can get you into a TCI 3000 converter and tranny cooler for $519.98. I can get those shipped to your door for $643.98. Add some tires that will hook at the track and you will see some 12's.
Brian
Thanks, how long can I expect the rear end to last? Has anyone tried the T/A rear end girdle?
V6toZ28 10-02-2003, 11:46 AM Originally posted by tim vestrand
3 years, 33,000 miles and 570 launches ...
Good deal, I've only got 14,000 miles on the clock! Is that a guarantee! Ha Ha
Black01_Z 10-02-2003, 02:50 PM I have a girdle and drag radials with a lead foot. Rear is doing good. :D
Mikie 10-02-2003, 07:38 PM Get those 2.73s out of that car!
Shame on GM for ever putting them there in the first place.
You need at least a 3.42 under there , but I would go ahead and drop a 3.73 in .
Do the gears and exhaust,lid and you will be there.
Get a lid and a power programmer so you can change up the shift points and firm up the shifts and you should be damn close! Iam sure the cold dry air up their will allow you to run 12's with those two mods. If that gets you within a tenth or so then get a catback and you will have your 12's!
Then get ready....you will want mid 12's then low 12's and finally 11's in a street car that is dead reliable and that is very attainable.
My buddy has a 35th A4 with 3.23's, 3200 stall, TR220 cam, mac mid lengths, borla cat back, pulley, lid, 160 thermo... He drives the car all the time no problems and has run a 12.16@110. and that was before the cam! Just waiting for the weather to cool down and Iam sure he will get his 11.xx@114.xx! You can see his car on the front page of Thunderracing's home page.
Hope that gives you some ideas on how fast these cars can be made to go!
Capn Pete 10-02-2003, 08:48 PM One of THE MOST important things:
TIRES :cool:
If tires alone don't get you there, then for one more single mod, a torque converter would definitely do it (with tires, of course;)).
Mikie, I'm afraid a set of 3.73's won't do it on their own:no:. I actually had 3.73's in my car for about 2 months earlier this summer, and I went to the track and ran the EXACT same time as posted in my sig, but actually 1 mph slower, and 60' times between 2.0 - 2.1:rolleyes:. IMO, that's not much improvement, BUT, if I had have put TIRES on the car, I think I would have hit 12's almost certainly.
However, the gears were Richmond's and they whined like hell, so I got sick of the noise and decided to swap back the factory gears (since I actually do more highway driving than I thought I did?!:rolleyes: ) and I'll look at other means of putting power to the ground right now such as tires, LCA brackets, *maybe a TC*, and eventually more motor!!;)
If you go gears with the A4 then go 3.42's at the most! 3.23's with a 3200 stall will do the trick....let the stall do the work! and with 3.23's the stall will work its ass off for you and when you are on the highway the revs won't be high!
Mikie 10-03-2003, 04:54 AM Pete,
You are right. Gears will net him about 2-3 tenths....if he can get traction. Not 12s by themselves , but with one or two more well thought out mods then all will be fine.
AL SS590 M6 10-03-2003, 05:30 AM Originally posted by V6toZ28
4 years, 25,000 miles and 500 launches. Big stall for the last 2 years.
DABIRD 10-03-2003, 09:12 AM Same boat here, I am looking for 12's also. I ran a 13.2 @ 106 when my car was bone stock. I wanted to be in the 12's so bad I called SLP the next week and order a lid, MAF, ATM, and a cat-back (loudmouth). From that I was only able to find 2 tenths -It is here that I encountered my newest enemy! TRACTION!!! My car now traps 110 mph cosistantly but more times than not I leave the line spinning. I can no longer get any better than a 2.1 60 ft. time either. I would deffinatly recommend a set of Nitto's or BFG DR's and aside from that cash in on all the "free mods" like the MAF de-screen, free ram air mod and and TB bypass, those are good for a couple extra horses.
Oh, and on the sounding stock thing, I dont think a cat back would hurt- since everyone and thier brother has that and a K&N, most people dont even consider those to be mods anymore!:)
Thanks for all the info, I will have to see how many of these things I can accomplish, With mortgages and all. As long as I can continue to SPANK my cousin's 4.6 Slowstang (Why do so many people buy these DOGS?) I will be content. Where can I find out how to do the TB bypass? Wil this affect Mileage, drivability etc?
Thanks all, TV
Capn Pete 10-03-2003, 01:34 PM Originally posted by tim vestrand
As long as I can continue to SPANK my cousin's 4.6 Slowstang ... I will be content.
Don't worry, the 'Stang has a LONG way to go to beat an LS1!!;) I'm not sure what they usually run, but I know the best I've seen so far at the track is 14.1 out of a 5-speed 4.6L 'Stang:cool:. Also, a guy at work ran his '99 GT and went 14.5 @ ~95 mph:p.
--->Throttle Body Bypass (http://www.installuniversity.com/install_university/installu_pages/sophomore_year/tb_bypass.htm)<--- :cool:
Also, a whole bunch of other cool mods @ InstallUniversity.com (http://www.installuniversity.com/install_university/support/installu_documents.htm) :).
95GRNZ 10-03-2003, 01:45 PM Originally posted by tim vestrand
You have nothing whatsoever to worry about unless he has plenty of mods. ;)
Why people buy them? My friend has a 00 GT Convertible and it is very nice. :cool: Wouldn't necessarily buy one (Maybe as a daily driver, though...:D), but they are nice. Especially the way they sound, even bone stock.
V6toZ28 10-03-2003, 03:11 PM Originally posted by AL SS590 M6
It was the last 80 launches on H/C that killed my rearend :(
robvas 10-03-2003, 03:50 PM Get a cutout.
02 Z28, A4, 2.73's, SLP Lid/Loudmouth and I go 13.06 @ 108 at Stanton. Are you going to M8 (http://www.migmevent.com)?
Maybe you could hook up a 100 dry shot ;) The NOS 5177 kits go dirt cheap on the board and eBay
You'll never hurt the rear end with 2.73's
It's good to know about the 2:73's, I would like to keep them as i do alot of highway driving and I like the gas mileage. I probably can't make M8, but you never know.
robvas 10-03-2003, 04:14 PM You might want to pull your MAF screen.
Will this mess anything up? what is the benefit? How do you do it?
Mikie 10-03-2003, 05:03 PM If you have to ask those questions then leave it alone.
Its a very minimal gain and some have experienced problems with it.
Seek other mods is my opinion.
Mike
Capn Pete 10-03-2003, 05:38 PM I agree............leave the MAF screen alone. There's hardly a measureable gain IMO, and besides, incase something gets past the air filter, it's like a last line of defence;). Apparently the problem that removing the screen will create is that the air flow across the sensing wires isn't "controlled" or properly directed (please don't quote me here?!:rolleyes: ) and the MAF won't give 100% accurate readings.
There are many different mods that you can do to achieve 12's, and I don't think that any of the "free mods" are gonna do it:think:............I hate to say that, but I'm in the same boat myself, and I've accepted the fact that to go faster costs MONEY!!!!:p Get yourself some tires, and then some type of power adder, whether it be additional traction devices, a torque converter, exhaust, a cam, or even N2O:thumb:. Now that you've got a case of the "I wanna go faster:o"'s, it's time to pull out the cheque book!!!!:D :lol:
95GRNZ 10-03-2003, 10:11 PM Originally posted by Capn Pete
Hehe... Now we just need camaro322hp in here... :D
imyeepeepaw 10-04-2003, 12:06 AM put a nos 100 shot and it will be in the 12 s easy and inexpensive
AL SS590 M6 10-06-2003, 01:13 AM Originally posted by V6toZ28
Darn it. I'm going heads/cam this winter. Guess I should be saving for a 12 bolt and a tranny build-up:( :(
