Clutch Replacement
Old Sep 30, 2003 | 10:50 PM
nat's Avatar
nat
Clutch Replacement
On average, at what mileage will a clutch need to be replaced in a Lt 1? I am looking at a '94 Z28 with 136k on it. How much longer do I have before the original clutch will need to be replaced?
Old Sep 30, 2003 | 11:03 PM
newbielt1's Avatar
Post
I also have a '94 and mine just went out yesterday with 108K on the good ol' clock. You gotta be careful because my clutch showed no sign of going out. It was not slipping at all, but it started to make a grinding noise, almost like two metal plates rubbing against each other when starting in first gear. The very same day it made that noise is when the clutch went out. When the shop took it apart I believe they said that the pressure plate was destroyed. I suggest you get it replaced sooner than later, keeping in mind that it's gonna have to be replaced anyways. Good luck and I hope this helped.
~~Wes
Old Sep 30, 2003 | 11:05 PM
nat's Avatar
nat
Thanks, dude. I appreciate it.
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
