steve10358 09-30-2003, 05:21 PM I want to remove my passenger airbag.
1. Is there any way, through program to eliminate the airbag code that will go off?
2. Will it disable the entire system?
3. Do I risk accidentally setting them off?
Dave89IROC 09-30-2003, 05:28 PM you can just put a resistor in the plug for the airbag, I'll try to get the resistance tommorow, the airbag controller will think there is still a bag in the circuit
steve10358 09-30-2003, 06:29 PM Get outta here! That'd be sweet. :)
You don't think anything will deploy, do you?
Steve
rpm4lalo 09-30-2003, 06:34 PM You can put the resistor on the brown wire or just cut it and tape off the ends with electrical tape.(that's how I got mine to go off)
Dave89IROC 09-30-2003, 06:35 PM you should have no increased risk of airbag deployment with a resistor in the pass airbag plug, the controller doesnt know the difference
make sure you disconnect the batt about 10 min before disconecting any airbag connectors though
I should be able to get the resistance value tomorrow, I have a friend that works at a pontiac dealer
steve10358 10-02-2003, 09:50 PM Any luck, bud? :)
reuter 10-02-2003, 10:28 PM whats the weight on the passenger airbag?
CCCCCYA 10-02-2003, 10:58 PM Hate to sound like Mr. Obvious, but why not just go ahead and pull the thing, test across the leads with an Ohm meter, and make a trip to Radio Shack? :)
Dave89IROC 10-03-2003, 07:08 AM Originally posted by CCCCCYA
I personally do not want to test across the leads of the detonator circuit of a live explosive charge
Originally posted by steve10358
Any luck, bud? :)
not yet, I havent been able to ge ahold of him
InjectedSS 10-03-2003, 07:12 AM Originally posted by CCCCCYA
Even better yet, why not just BYPASS the entire thing all together :D
Do what I did, take all of them out, remove the airbag light outa the dash, sell the airbag's and buy go fast stuff :thumb:
95_RipperZ 10-03-2003, 08:44 AM Originally posted by InjectedSS
Thats my plan. How much did you get for your airbags? Is there a writeup on how to take them out? I have no idea where to start besides taking the dash off.
InjectedSS 10-03-2003, 11:13 AM Originally posted by 95_RipperZ
I got like $300 for both of mine.
No write up that I know of. Pretty much just pull the dash and rip them out :) Like I said, I just disconnected all the lil Air Bag computers and sold those too :) There's one in the passenger side behind the glove box, it's a square metal box. Then there's another one in the center console like right below the cup holder in the center console. Pretty much everything that had yellow connector's was all air bag crap. Then I just removed my air bag light so I didn't have to look at it being on.
Good to go from there :thumb:
BTW that passenger side one was pretty heavy :)
When you pull the airbag put you need 1.6ohm of resistance to fool the computer into thinking the airbag is still there. I used two 3.3ohm resistors in parallel on my 2002.
When I traded this Z28 in they called me the next day asking for the airbag. Apparently they could only sell it wholesale without one and dealer cost was over $1000.
theratdude64 02-05-2008, 12:03 AM Been searching and can't find it.
How can I remove the passenger side airbag? I'm puttin 97+ dash in and I have the dash sitting right here and don't see how to remove it. I hear its like 8 bolts but :confused: or will the 97+ Bag work in my 95? Same Plug?
