grygst76 09-30-2003, 01:53 PM This is definitely not for lt1tech IMO but, why does GM not recommend 10W-40 in our LT1 motors? I just started using it the first time and my oil pressure has never been better? @idle it used to be a pubhair above 20psi at normal op, now it is around 30psi and regular load driving @1500RPM's it is still a little above 40psi. What gives?
Thicker oil kills HP.
Daren
Injuneer 09-30-2003, 02:36 PM You only need 10psi per 1000rpm to lubricate the engine. You are wasting energy by pumping thicker oil at a higher pressure. The engine is designed to survive with the cooling and film thicknesses provided by the viscosity of a 30-weight oil.
grygst76 09-30-2003, 02:48 PM I just did not understand it since my 67 327 I ran 20 50 thru it and never had a problem, I know about pressure formulas and horsepower loss I was just curious why they say not recommended...I willl be changing it out to 10-30 this friday but GM never gives a thorough explanation.
OldSStroker 09-30-2003, 04:52 PM Thicker oil also cuts fuel economy. With high mileage emission and lifetime fuel economy targets, OEMs design for lower viscosity oils. They especially like synthetics, like M1 factory fill on Vette.
Lonnie Pavtis 09-30-2003, 08:51 PM GM designs clearances tighter these days in comparison to the early small block engines. Thick oils are suitable for big bearing clearances but may not flow properly in engines with tight clearances.... especially when cold. Some safety has to be built in for the moron that holds it to the floor 30 seconds after a cold start-up. Aluminum motors may also have tighter main bearing clearance when cold to compensate for the greater expansion that aluminum has over steel.
As stated in previous posts, thin oil gives better mileage & HP... a big deal when federally mandated fuel economy standards can cost auto manufacturers penalties when cars produced are below a certain limit.
Will 10w40 work? Yes it will & also may help reduce the oil consumption problems that some LS1 motors exhibit. I have 2 examples (5.3 Chevy trucks) locally where this helped. Also a customers stock bottom end '99SS is running low 10's at 7000rpm on 10w40. Would it blow up or go faster on 5w30.... not sure if either would happen but I hate to mess with what works.
Do I recommend it to anyone reading? No, mainly because I do not want to be responsible for your engine, but I would do it on mine after it racked up some miles.
Just something to think about.
"White Knight" 10-01-2003, 10:10 PM Here's my special mix:D
4 quarts of Vavaline synthetic 5W-30
and i quart of lucas oil. Oil pressure runs perfect, and helps reduce blowby since the rings and everything is worn.
"White Knight" 10-01-2003, 10:13 PM Confucious say "oil is oil" Just depends on how much you want your pump to have to work:D
Transamdriver 10-02-2003, 03:51 AM Originally posted by "White Knight"
:eek:
You put that glorified gear oil in your engine?:no:
The only thing that stuff does is cause the oil to foam in certian situations due to the fact it doesnt contain the anti-foaming additives that normal oil contains.
Whatever floats your boat I guess.;)
Injuneer 10-02-2003, 06:24 AM Originally posted by "White Knight"
Please explain what you mean by "Oil pressure runs perfect"
grygst76 10-02-2003, 07:15 AM As far as fuel economy, I haven't changed my driving habits and I filled my tank on monday and today I have 1/2 a tank and my mileage says 250 so fuel economy is not affected.
FastZinTennessee 10-02-2003, 08:43 AM I usually do five quarts of mobil 1 10w30. Last time I did four quarts of 10w30, and one quart of 15w50. I get better pressure than I did before. However I do still have some spikes in oil pressure under heavy acceleration, but no one seems to be able to figure it out.
S.J.S. 10-02-2003, 09:40 AM Hey John.....go figure.....thats the same mixture I was planning on running in my motor.
FastZinTennessee 10-02-2003, 02:40 PM It seems to work really well. From what I have read Mobil 1 is a little on the light side for a given weight. IE there is a range that you can be within and still classify the oil as 10w30, and mobil 1 is on the light side of that range. I got a lot of good info off of www.bobistheoilguy.com
Great forum, and great group of guys over there.
John
Got-LT1 10-02-2003, 06:53 PM My car actually runs better and quicker with the 5W50 castrol syntec.
96TurboTA 10-02-2003, 11:22 PM I use 20w50, but that's what my engine builder told me to use.
I did a bunch of back to back oil tests a couple of years ago and found that the light weight synthetics were always faster.
In my new Top Stock LT4 I will be running 3.5 quarts of 0-10 weight.
Daren
FastZinTennessee 10-03-2003, 11:33 AM GUMP- :eek: What kind of oil pressure do you get with that?
S.J.S. 10-03-2003, 01:34 PM Originally posted by FastZinTennessee
No kidding. Why are you gonna do that?:confused: You must be wanting to rebuild your motor bad. :cool: For one that's way way thin and you only running 3.5 quarts?:rolleyes:
I can say one thing....good luck and I hope your just real smart.
rskrause 10-03-2003, 01:58 PM I am currently using 10W-40, I used to use 15W-50 in blower + N2O car. I realize it costs some hp, but I like the idea of protecting the bearing aginst the "shock" of the nitrous hit.
Rich Krause
This is a drag race only thing. It makes quite a big difference in ET.
I only run a factory pump and restrict all of the center drain backs in the lifter valley. As far as oil pressure goes, I really don't think that it is that important for the short period that I am at WOT. You would be really surprised at how good the bearings look when I tear the motors down at the end of the season.
Daren
Damon 10-03-2003, 04:35 PM Daren- I'm guessing you pull about 40 PSI off the line and close to zero through the traps in top gear?
I used to keep taking oil out of my motors at the track until I started to lose serious oil pressure at the top end. I wouldn't let it get to zero or anywhere near it, but back then I was not familiar with synthetic oils and their "magical" properties. I was just running parts store oil. It could get me a solid tenth, maybe a smidge more on a car only running 13s and shifting at 5500. On a faster, higher winding engine the benefits are probably magnified.
However, it should be noted that this is DRAGSTRIP ONLY kinda stuff. Driven on the street like this the motor would become a paperweight very quickly.
