xxsaint69x
09-24-2003, 10:27 AM
Well, i finally ordered the street twin.
I was wondering if there is anyway i can test my Slave cylinder to make sure its still working like it should.
Also where can i get JUST the Slave. Thanks
Also, how do i go about bleeding evertyhing after i put the Mcleod master cylinder.
Marcin
PatriotTA
09-24-2003, 11:15 AM
I don't think its possible to get just the slave. I'm pretty sure GM only sells the whole hydraulic assembly. Install University has a writeup on the McLeod master cylinder install HERE (http://www.installuniversity.com/install_university/installu_pages/sophomore_year/drill_master_cylinder.htm). Granted its for an LS1, but it has a procedure for bench bleeding which should be the same for both LS1s and LT1s. After bench bleeding, I assume you just bleed it on the car like your normally would. Let us know how the install goes.
xxsaint69x
09-24-2003, 11:55 AM
it has to be possible as few people on the board got some...but non of em say where from!
I got just the slave from a local parts store, I think it was around 70-80$ bucks? I saw no reason to buy the whole damn thing from GM since I got the awsome adjustable one with the kit.
PatriotTA
09-24-2003, 12:19 PM
Maybe try Murray's or AutoZone. Just call em up on the phone...
xxsaint69x
09-24-2003, 03:35 PM
is there a way to test the slave to make sure its working fine?
