KASR_Z28 08-11-2002, 02:12 PM Has anyone here been able to successfully shoot 100hp n20 in 1st gear past 3k rpm without losing complete traction? Tips?
KASR
94 Z28 Hardtop - (stock: 10.5:1, 5.7L, rated 275hp@5200, 325lb@2400, MFI - Current Rating: ???)
Throwing money at the hungry beast and moddin' away like a mad-man =) Holley CAI, !TB, !MAF, Flowmaster Catback, Monza Quad Tips, 3" cutout, 3.23 gears GU5/G80 perf. axle, QLC, 4L60-E, Spectre Breather and Filter, Autolite 103 plugs, wires, and filter, MSD 6A, Compucar n20 125, Comp TA BFG Drag Radials
MODS TO COME: Jet-Hot Hooker Long Tubes, Yank 3000 TC, cc305 cam, 1.6 rockers.
LPEdave 08-11-2002, 02:19 PM You mean sticking with the drag radials, or are slicks allowed in your plan? With ET Streets it's certainly possible.
Dave
1997 LPE 383/n2o Camaro Z28 Convertible (http://www.go-fast.org/z28)
12.39@112.2, 1.76 60' (na) 11.27@124.6, 1.76 60' (n2o)
LT1 Diagnostics (http://www.go-fast.org/z28/diagnostics.html), New to Nitrous? (http://www.go-fast.org/z28/new_to_nitrous.html) Northern California Racing Club (http://www.ncracing.org/)
n2oTransAmLT1 08-11-2002, 02:23 PM Yep..It's possible. I do it every day on my street tires. They are Yokohamas. I get minimal spin the whole time in first and about half of second. I dont think its slowing me down any cause I absolutely destroy everyone around here in first gear with a 100 shot. Of course, if you have drag radials or slicks then that will always be better then street tires.
Oops..I forgot to mention that I usually spray at about 2700rpm in first. Maybe you spin the tires alot cause your hitting it while you are already at peak touque...not a bad thing.. http://web.camaross.com/bb/smile.gif
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit with all the extras, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, NGK TR6 plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
UPDATE(8-02-02) Moser 12 bolt is here.
[This message has been edited by n2oTransAmLT1 (edited August 11, 2002).]
Derrick Redd 08-11-2002, 05:54 PM ET Streets or ET Drags should do the trick. http://web.camaross.com/bb/wink.gif
<A HREF="http://personal.msy.bellsouth.net/msy/k/r/kraest/derrick.htm" TARGET=_blank>1994 Z28 A4
LT1 Motorsports equipped stock-bottom end LT1, LT1 heads, Hydraulic-Roller Cam, Dope
11.03 @ 125.53 1.61 60ft.
7.08 @ 99.05 1/8 mile</A>
<A HREF="http://stangnet.cardomain.com/member_pages/view_page.pl?page_id=229662" TARGET=_blank>1984 Mustang L
92' 5.0 roller motor, T5, NOS plate kit, etc.
14.03 @ 100.51 2.29 60ft. NA on street tires
Dope with slicks ????
</A>
NVMYZ28 08-11-2002, 07:05 PM I can hit it in first gear at 2500 rpms - lets just say its interesting http://web.camaross.com/bb/wink.gif
However at the track - I hit it in first gear with the slicks - NO traction problems at all. Just goes!
Jeff C - Utah
1994 383 Z28 M6
Bored, Stroked, Splayed, and Sprayed!
www.nvmyz28.com (http://www.nvmyz28.com)
Utah F-body Assoc. (http://www.ufba.org)
1989gta 08-12-2002, 11:39 AM yeah i have the same problem. I'm all over the road going to try the slicks i have nittos right now. they work great for just the motor but can hang with the juice.
