lt4 clutch disc in z28
zjet
09-23-2003, 01:39 PM
i was told the lt4 disc wont work with a camaro flywheel is this true .thanks
PatriotTA
09-23-2003, 02:01 PM
It should work if its the LT4 Camaro disc. Although I think some of the LT4 discs may have been built for the dual mass flywheel, which was used in the Corvette. That means that the disc is not dampened, its a rigid disc, because the dual mass flywheel is dampenend instead. A rigid disc would not be very streetable at all. But if it is dampened (has springs in it) you should have no problem with the stock Camaro flywheel. I think all the Camaro LT4 discs were dampened, while all the Corvette LT4 discs were rigid, but I could be wrong.
