widest 28-29 inch tire??
lt1camaroman93
09-22-2003, 11:57 PM
What is the widest 28-29 inch tire you can run in a 4th gen with a 15x10. i don't mind cutting stuff out of the inner well or whacking with a hammer. either ET drag or ET street
89ProchargedROC
09-23-2003, 12:21 AM
biggest tire is a 29.5x10.5W.....needs A TON of work and practically a minitub to fit
lt1camaroman93
09-23-2003, 06:58 AM
Thats a tall tire man. How in the world does it fit? my 28inch drag radials only leave me a half inch between the tire and the rear quater.
Smoke T/A
09-23-2003, 08:32 AM
I have seen a 28x12.5 et street fit with minimal clearance.
spraytheway
09-23-2003, 09:25 AM
I've got a 30 x 12.5 x 15 ET street on my car and it wasn't an easy one.
Vince
lt1camaroman93
09-23-2003, 11:01 AM
do you have any pictures of the 29.5 or the 30 inch tire on the car?
spraytheway
09-23-2003, 11:16 AM
I do have pics of the car with the 30x12.5x15 on it but they are not digital just regular old pictures. Sorry, I would love to show them but I can't. :(
Vince
lt1camaroman93
09-23-2003, 11:22 AM
Well that sucks. I am going to buy new tires on friday and i don't want to have to spend more than 4 hours trying to make them fit. Could you clue me in on some of the stuff that has to be smashed or cut off. i am most likely going a little bit shorter of a tire than you but it would still be nice to have a place to start.
Brady
09-23-2003, 02:43 PM
I have 30" tires on my '96 Z28. IMHO, to do it right you'll need to trim the front of the wheel opening back at least an inch, that requires paint/body work.
It will take considerably more than 4 hours to do it right.
28" tires will be your best bet. Here's a couple pics: http://turbocharged.net/twinturbo/rebuild2003/cage-tires/
http://turbocharged.net/twinturbo/rebuild2003/done/
lt1camaroman93
09-23-2003, 11:32 PM
that is one huge drag radial!!! i don't think i am down for trimming off the front of the wheel well but the back maybe.
Pro Stock John
09-24-2003, 10:52 AM
It's not a lot of work to fit a 28 x 10.5 x 15 or it's DOT equivalent on a 4th gen.
I am running a 28x10.5x15 Hoosier slick on the back of my 98 Formula.
I am contemplating a move to 29x10.0x15 Hoosier slicks but I may have to do a lot of clearancing I will decide once I dyno the car.
How much gear you going to run, and what traps you run?
With a 28 and a 4.10 and T400 I am looking at being able to do 7000 rpms.
lt1camaroman93
09-24-2003, 02:03 PM
the reason i am looking at a 29inch tire is because i am hitting the rev limiter 20-30 feet prior to the traps at 118mph at 5850 rpm. i run a th350 with a 3.23 gear and 28inch tire. the converter is realy loose i think that is what is causing the problem so i am just looking for a fix for the rest of the year. then i will get a better converter and step back down to a 28 inch tire or a bit more gear. the converter is supposed to be a 3600 but if i pull up the e-brake and hold down on the foot brake, it will hit 4100-4200. i only did this because i suspected the converter was loose.
Pro Stock John
09-24-2003, 02:17 PM
Raise the rev limiter, you running stock springs or something? :)
lt1camaroman93
09-24-2003, 02:24 PM
acctualy, yes. stock everything that thouches oil. I am hoping to get enough money to start on the top end this winter along with a new trans and converter set up. Will i loose anything going from a th350 to a th400?
Pro Stock John
09-24-2003, 02:35 PM
You running 4.10's? Stock rear?
lt1camaroman93
09-24-2003, 11:43 PM
running a 3.23 gear, stock rear.
lt1camaroman93
09-27-2003, 02:37 AM
i bought the tires today. M/T ET streets. 28x13.5x15. Talk about hitting stuff with a sledge hammer and cutting A LOT of stuff out of the inner wheel well on one side. Then trimming back the bumper cover. Looks sick with a tire that big on it though.
sideways_Into_3rd
09-30-2003, 02:33 PM
I run 28x10.5x15 ET drags on 15x10 prostarts with 5.5" BS without touching the inner wheel well .. just had to put in adjustable LCAs and bang in / cut a bit of the rear wheel well
they look pretty good .. stick out a bit .. so i adjusted my HALs accordingly ;) heres some pics
wheels up (http://www.sfu.ca/~pkavousi/Picture%20001.jpg)
front view (http://www.sfu.ca/~pkavousi/mrp/117-1784_IMG.JPG)
front low (http://www.sfu.ca/~pkavousi/mrp/117-1785_IMG.JPG)
rear view (http://www.sfu.ca/~pkavousi/mrp/117-1786_IMG.JPG)
... and this (http://www.sfu.ca/~pkavousi/mrp/117-1795_IMG.JPG) is what 10.5 ET Drags do to ur 12 bolt if u dump ur street twin at 6000 rpm ;)
Brady
09-30-2003, 05:17 PM
I don't think I've ever seen anyone hammer there fenderwells quite like you did.. :o
Pro Stock John
09-30-2003, 05:21 PM
Brady is mean. :)
sideways_Into_3rd
10-01-2003, 12:06 AM
u mean my fenders ??? :p
yeah .. my anger management mentor pissed me off
