Adjusting a PHR
locosteelersfan
09-22-2003, 10:51 PM
I have a Hotchkis unit on the way and
need some tips on the adjustments, install university gives
their usual good write up but its on a non-adj
unit.
THANKS
TA Dreaming
09-22-2003, 11:00 PM
well im sure there may be a quicker way then what i did, but i raised the rear(i have access to a lift). dropped the old one out. adjusted the new one to the same length. installed the new one. used loctite blue on the bolts. lowered the car onto its own weight. took a peice of wire and put a heavy bolt on one end. taped the other to the middle of the fender. let it hang. its called a plum bob. you can make it with fishing line string whatever. took a measurement from the center of the rim to the line on both side. raised car back up adjusted some i the right direction then lowered it again and checked the distances. i did this til they were the same on both sides. it worked for me maybe theres a quicker way, but thats the general idea. trey
