Erik
09-20-2003, 01:05 PM
1980 Z28
automatic, 2500 stall, 3.42 gears, all suspension meets oem specs. + slapper bars.
26x10.5 ET Streets
400+hp at the crank
runs 13.0's @108 on street tires
runs 13.0's @105 - 107 on slicks, depending on tire pressure pressure.
I've run the slicks at 16, 15, 14, 13 and 10 psi. at all pressures I get 2.0x 60 times, and 10 psi is a little scary with the car wandering all over the road. I've tried a variety of launching techniques and the best seems to be to bring it up to 1800rpm, then hit 3/4 throttle as soon as the light comes on, quickly 'rolling' the pedal to the floor. I've tried going full throttle, but the tires spin. Anything above 2000rpm and the tires break loose, and I get pushed through the lights.
What do I need to do start pulling some decent short times? As things are now, I can get better short times on street tires :irk:
26x10.5 ET Streets
400+hp at the crank
