60' ft times?
Rodrigues
09-18-2003, 11:00 PM
I was wondering what my 60ft times might be launching with a street twin/11.5" et streets assuming a well prepped track and 500 rwhp (nitrous)
What RPM should I launch at?
Would I bet able to lift my front wheels with skinnies and a 3600 lb car with me in it?
AL SS590 M6
09-19-2003, 12:20 AM
Rod442 pulled a 1.53 on a 5500rpm launch with his 500rwhp TT Formula weighing 3800+ and yes it picked the wheels up.
KGRESOCK
09-19-2003, 02:24 PM
Got any suspension mods???
red
09-19-2003, 02:27 PM
Assuming you have the suspension worked out so it plants the power properly you should be able to get a mid to low 1.5 60'.
With my set up I leave at 5,800 RPM, with the ET drags set at 11 psi. This gets me 1.52 - 1.55 in the 60' with the fronts about 8 - 12" off the ground.
TedH
09-19-2003, 04:58 PM
My guess is 1.5's. Suspension work would be minimal with springs, shocks, roll bar and subframes. 12 bolt would be warranted unless you want to be towed home.
Rodrigues
09-19-2003, 06:35 PM
I have stock suspension :(, yes there will be a ford 9"
KGRESOCK
09-19-2003, 07:47 PM
Stock torque arm? LCA's? Driveshaft?
Your new street twin is going to eat everything.
You need to improve your suspension. Throwing
a nine inch in is a awesome start now finish it off
with some A1 launch components.:)
Rodrigues
09-19-2003, 08:34 PM
What should I do at the moment that isnt going to cost me an arm and a leg, this rear end is going to take practically everything I got at the moment.
KGRESOCK
09-19-2003, 09:00 PM
My .02
At a absolute minimum you would need a good
torque arm and sub frames if you don't have them.
Will your stock ta even fit your 9"?
KGRESOCK
09-19-2003, 09:02 PM
BTW...
I will be upgrading some of my components soon,
BMR LCA's and PHR.
Shoot me a pm if interested.
Rodrigues
09-19-2003, 09:20 PM
I have SLP diamond subrframes, i dont have lcas though.
red
09-20-2003, 11:22 AM
I would suggest aftermarket TQ arm and LCA's. Also make sure you get a top quality TQ arm such as the BMR extreeme or Madman's. When you are pushing a M6 to the 1.5 range there are tremendous shock loads that the TQ arm has to absorbe. I have broke three in the past (2 Spohn & 1 S&W).
I would also suggest adjustable front and rear shocks. With out the quick weight transfer you will have problems getting the M6 to launch hard.
ltlhomer
09-22-2003, 07:17 PM
Patty boy just got a set of tubular lca's. How much is a good torque arm? I'm not sure if I can get one that mounts to its own brace because of my true duals. They might pose a problem.
