Love Potion #9
06-22-2002, 01:37 AM
What will happen if I stick w/the ACDelco plat plugs on a 75 or 100 wet shot?
Do I HAVE to go colder plugs with nitrous?Love Potion #9 06-22-2002, 01:37 AM What will happen if I stick w/the ACDelco plat plugs on a 75 or 100 wet shot? roofo 06-22-2002, 03:38 AM BOOM!I guess.I hear it's not good.Plugs will melt I guess. [This message has been edited by roofo (edited June 22, 2002).] RacinLT1 06-22-2002, 10:09 AM If you stick with the platinum plugs on nitrous,you will melt the platinum off the plugs and go from stock gap,to twice the stock gap. DO NOT use platinum plugs,dont have to go colder. But each car is different. ------------------ Dirk 1997 TA A4, Finally Legal to 10.00 (now i just gotta get it to go that fast) The RacinLT1 (http://hometown.aol.com/racinlt1/myhomepage/index.html) RacinLT1 pic's (http://photos.yahoo.com/racinlt1) Love Potion #9 06-23-2002, 04:02 AM Will colder plugs effect the performance of the car when I am not runnin the juice thru it? Derrick Redd 06-23-2002, 08:17 AM Definetly don't use platinum plugs. http://web.camaross.com/bb/eek.gif If you go 1 or 2 heat ranges cooler it shouldn't affect you NA. I run 2 heat ranges cooler and my car runs great NA and on the dope. http://web.camaross.com/bb/wink.gif ------------------ <A HREF="http://personal.msy.bellsouth.net/msy/k/r/kraest/derrick.htm" TARGET=_blank>1994 Z28 A4 LT1 Motorsports equipped stock-bottom end LT1, LT1 heads, Hydraulic-Roller Cam, Dope 11.03 @ 125.53 1.61 60ft. 7.08 @ 99.05 1/8 mile</A> 1984 Mustang L 92' 5.0 roller motor, T5, etc. 14.03 @ 100.51 with a spinning 2.29 60ft. [This message has been edited by Derrick Redd (edited June 23, 2002).] asianice25 06-25-2002, 01:08 PM I would change the plugs as well, i run regular delcos at the moment, but im changing to NGK TR-6's when i put my headers on(a month or so). However, if you spray 75 on stock plugs you shouldn't have a problem, because its the ignition/ntrous combo that screws you. itll melt the electrode right off, but the stock ignition isnt hot enough to do that, unless your case is extreme. ------------------ Scott Parkinson 2001 Sunset Orange Z-28 SLP Loud Mouth, K&N, Mass Air, 160 Thermistat, Power Programmer, All aftermarket suspension/braces, 8.5mm Plug Wires, 125 hp Shot. Runnin low 12's all day. n2oTransAmLT1 06-26-2002, 02:15 PM FWIW..I am running a 125hp shot on my internally stock LT1 with lots of bolt ons and REGULAR SPLITFIRE PLUGS. Stock heatrange, just gapped smaller and have never had a problem through 80lbs of nitrous. | ||
