T56 swap, 12k miles, upgraded.
Old Sep 17, 2003 | 08:08 PM
Rodrigues's Avatar
I have a T56, this is what it includes
*A Tremec T56 for a 1995 camaro (.5 overdrive), 12,000 miles on the trans
*3-4 gear has a brand new steel fork installed
*Bellhousing
*Inspection plate
*Clutch pedal
*(2) Master cylinders
*Hydraulic line
*Slave cylinder
*(2) Pressure plates
*Clutch disc that almost looks brand new
*Flywheel (Will need to get balanced to your old flexplate/converter or however your engine is balanced)
*You can have the old aluminum forks too, they were not bent, just preventative maintence.
*Stock shifter assembly (I highly recommend an aftermarket shifter with stops though)
*Trans crossmember
*Energy suspension mount
http://kak.com/trans/DSCN1127.JPG
http://kak.com/trans/DSCN1128.JPG
http://kak.com/trans/DSCN1129.JPG
http://kak.com/trans/DSCN1130.JPG
http://kak.com/trans/DSCN1131.JPG
http://kak.com/trans/DSCN1132.JPG
http://kak.com/trans/DSCN1135.JPG
http://kak.com/trans/DSCN1136.JPG
http://kak.com/trans/DSCN1137.JPG
I am looking for possible trades
$1600 for everything
Old Sep 18, 2003 | 01:49 PM
Timberwolf's Avatar
hmmm :thinks:
Old Sep 18, 2003 | 02:40 PM
Rodrigues's Avatar
Just PM me with offer/trades....
Old Sep 18, 2003 | 03:27 PM
z28ke's Avatar
You've got a PM
I looked at the pics and only saw one pedal, the whole assembly isn't included?
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
transam_388
Mar 15, 2015 11:53 AM
ddr698
Jan 9, 2015 10:05 AM
cmdeshon
Jan 4, 2015 11:15 AM
nballisru
Dec 14, 2014 05:01 PM
