Will valve stem lash caps increase lift?
MattysTA
09-16-2003, 11:07 PM
I was wondering if and how much if any would using lash caps on the valve tips would increase lift. say if you were using 1.6 rockers and the lift on the cam w/rockers is 520 in/ex how much more would lash caps increase the final lift if any. the lash caps are .06" thick. thanks.............
SStrokerAce
09-17-2003, 06:22 AM
Nope,
only lobe lift and rocker arm along with the lash setting give you max lift.
Bret
