Verticle vs Horizontal bottle mounting
NVMYZ28
06-08-2002, 04:02 PM
I have only seen this discussed *lightly* in the past. I was just curious as to who has their bottles mounted Verticle - and are you seeing any issues with it? If you are please let me know.
I am chasing a N20 "sputtering" problem right now - seems like I cant get all the air out of the line - my bottle is currently Verticle - but it is 100% full.....
Please post your thoughts on Verticle vs Horizontal - the bottle that is http://web.camaross.com/bb/wink.gif
Jeff C - Utah
1994 383 Z28 M6
Bored, Stroked, Splayed, and Sprayed!
www.nvmyz28.com (http://www.nvmyz28.com)
Utah F-body Assoc. (http://www.ufba.org)
Bottlefed3.8
06-08-2002, 06:27 PM
45 degree is the best way to go. When you have it vertical it settles to the bottom. It is gas but it is still cold and cold air (which has nitrogen and oxygen in it) sinks. Hope this fixes your problem. Also if you dont have a purge kit get one.
2001 Camaro V6 A4
A few mods. :-)
KTamez
06-09-2002, 02:23 AM
Either one is just fine. The key is to be sure the siphon tube is pointed to the rear of the car. If the bottle is vertical, the Valve/feedline needs to be pointed to the back of the car (Label Facing the dash).
Angled/Horizontal is better IMO, but vertical should work just fine for ya so long as the bottle is pointed the right way. http://web.camaross.com/bb/smile.gif
Good luck!
Kurtis Tamez
LT4-396.com (http://www.lt4-396.com)
97 Z28 LT4-396
94 Firehawk LT1-396
nosfed
06-09-2002, 03:37 PM
I've seen a few lately with the siphon tubes removed, and the bottles mounted upside down. I'd like to know if there's any advantage to that.
NVMYZ28
06-09-2002, 06:45 PM
Now that is an interesting idea....... Thats how the refill stations bottles are mounted - so I suppose it really wouldnt matter.......
Jeff C - Utah
1994 383 Z28 M6
1989gta
06-14-2002, 11:32 AM
A buddie of mine had sputtering problems when his fuel pressure saftey switch was bad.
Thats interesting about taking the tube out and mounting upside down.
