Best way with nitrous?
mjcent922
06-09-2002, 01:53 PM
Just wondering thinking of running nitrous on my 94z28.Wet or dry?do I need any fuel or ignition up grades?Nx or TNT seem like the bet two chices out there.I plan on running a 100-150 shot.How many step colder plugs should I use?Also anyone have a price on install of systems?
[This message has been edited by mjcent922 (edited June 09, 2002).]
taner
06-09-2002, 06:51 PM
1. wet...safer on a larger shot
2. TNT they have a plate for our lt1's
3. timing retard module is a must
4. plug depends on how much you spray, i would use a ngk tr8 plug, so 3 steps colder
5. i would upgrade the fuel pump
keep in mind my thoughts on this are running safely, especially if you are spraying a stock bottom end. you can always go down to a hotter plug or add more timing if it is running a bit slow, but once you blow a pistion or ringland it is too late. my .02, g'luck
Brent94Z
06-09-2002, 07:11 PM
Welcome to the Board! Don't forget we also have a dedicated nitrous forum http://web.camaross.com/bb/biggrin.gif
I'll move this there for you http://web.camaross.com/bb/smile.gif
Brent Franker * Main Page (http://www.bfranker.badz28.com/)
94 Vortech Z28 (http://www.bfranker.badz28.com/94z/94z.htm) * 96 Z28 SS #1655 (http://www.bfranker.badz28.com/96ss/96ss.htm)
4th Gen Appearance Modification Guide (http://www.bfranker.badz28.com/appearance)
F-Body Install & Fix-It Guides (http://www.bfranker.badz28.com/fbody/guides.htm)
mjcent922
06-09-2002, 10:40 PM
Thanxs Brent!This place is great!
94Z28DOJ
06-10-2002, 04:53 PM
Most people run the NGK TR6 plugs or Autolite 103's. Fuel pump is usually good up to a 150 shot, but if you don't have the money for a rebuild you should upgrade it. You and a friend should be able to do the install in about day.
[This message has been edited by 94Z28DOJ (edited June 10, 2002).]
