WhiteHotSS
09-07-2002, 11:39 PM
I used to have a 97 z28.I changed the tires but kept the old tires,not sure of the exact size but they are 16 in.My father in law has a 97 camaro also,but a V6,has anyone here ever used tires from a Z before? I'm wondering if they will fit on the rim ok.
Thanks for the help
blue95
09-07-2002, 11:59 PM
The tire size on your Z28 should be a 245/50/16. Although some came with a 235/55/16. The first # is the width the second # is the profile. All the tires can be interchanged that came on the f-bodies. v6 z28 regardless(unless of course 17")
Matter of fact in technically a upgrade for him because your tires are wider and have a slight smaller profile. I have a v6 and went with the 245/50/16 when I had the chance. Another words they will fit!
If you own a V6 Camaro or Firebird you need to be here!
http://www.fbodyv6.com/index.php
I run 245/50-R16 Whitehot,on a 8" rim.
T.
_ _ ______________ _ _
Hella Clean Dark Green Metallic 98 3.8 L60E Coupe:Fast toys Ram Air,Holly filter,Whisper lid,Jet stage2 PCM,160 Thermo,Man.fan switch,Purple ice wetter,Eibach Pros,Koni adjustables,BMR sways,Prothane bushins,Transgo kit,Magnaflow cat-back.National Auto Sport Ass. member/student.
WhiteHotSS
09-08-2002, 09:03 AM
Thanks for the help guys,I really appreciate it.
