complete T56 swap
complete T56 swap
I mean complete.....most setups dont include a complete M6 engine harness or M6 PCM.
Includes:
-used LT1 T56 tranny (2nd gear grinds very slightly only when shifting fast, normal driving does not grind, goes in gear every time, no popping out....basically not a big deal)
-bellhousing
-stock clutch w/17k miles
-flywheel
-hydraulics
-M6 pedal assembly
-complete M6 engine harness (94-94 LT1)
-95 OBD 1 PCM with stock M6 program
-inspection cover
-crossmember
-shifter
-exhaust mount and torque arm mount brackets
-complete console with trim covers, shifter boot
-M6 driveshaft (stock)
-all nuts/bolts
$1500 with PCM and harness
$1300 without PCM and harness
I would like to sell this asap, and would prefer pick up in western NY state, or I would be willing to meet buyer part way (If driving from Ohio, Mid Atlantic region, New England, Indiana, Kentucky, etc...)
jhsformula@aol.com
Jason
Includes:
-bellhousing
-flywheel
-hydraulics
-M6 pedal assembly
-inspection cover
-crossmember
-shifter
-all nuts/bolts
jhsformula@aol.com
Jason
T56 Swap
Jason,
I want your T56 setup. Can you or will you take a credit card? I can bring around $400 to $500 cash but the rest I will have to put on the card for now. Let me know what you think. thanks a ton.
