Someone help!! Starts up but turns off in 1 sec
LT1RX7
09-14-2003, 05:23 AM
I just started up the LT1 engine in my RX7 but I'm having an issue. The engine starts up but only stays on for about a sec then turns off. Even when I have the throttle 1/2 open it'll idle high then turn off. I'm thinking it's a computer problem seeing how it just turns off no matter what throttle I give it. I don't have the O2 sensors in yet but I think it should still idle. Would an LT1edit tel me the prob?
madwolf
09-14-2003, 05:27 AM
Did you disable VATS?
shoebox
09-14-2003, 01:15 PM
MAF connected?
LT1RX7
09-14-2003, 02:48 PM
MAF is connected and VATS was deleted from PCM
TriPinTaZ
09-16-2003, 12:00 AM
is your MAP sensor installed?
LT1RX7
09-16-2003, 01:40 AM
it is installed but wheather it's working or not is a different story. My freind had a map sensor go out but it still ran, just like crap
rskrause
09-16-2003, 03:10 AM
Codes?
A big vacuum leak will do this.
Rich Krause
LT1RX7
09-16-2003, 05:32 AM
how about that big rubber thing that a pipe is suppose to stick into? It's on the driver side that I think goes to the valve covers. Could that cause a vacuum leak? Mine is not plugged
LT1RX7
09-16-2003, 05:48 AM
OK, I found that and the low oil sensor was broken completly off. Could the PCM be sensine no oil pressure and turn the engine off?
shoebox
09-16-2003, 06:11 PM
It could if there was a wire going from the sensor to the pcm, but there isn't. The only wire coming from the oil pressure sensor goes to the gauge.
turbo_Z
09-16-2003, 07:55 PM
when you turn the key to the on position just so you have power from the battery, does the SES light flash or do your fans turn on?
LT1RX7
09-16-2003, 11:59 PM
the SES light goes on but does not flash. I found that the hole in the intake is for the PCV or something
chevysam
09-23-2003, 04:54 PM
Are you using a Camaro or Corvette computer?
I just did a swap using a Vette computer and I'm having the same problem. I have used Camaro computers with no problem. The VATS system ties into the Vette PCM in a different way.
