1979 z28 350
Old Sep 14, 2003 | 12:44 AM
xItsMike's Avatar
1979 z28 350
Hi, just bought this z28 5.7L 350 4spd manual, so i may be posting here regularly now. I know next to nothing bout engines, mods, etc so ill be exploiting all yours expertise and your yearning to show it off!
anyway, the car is all stock and i dont have to money right now to be putting into it but soon enough I will - so i ask now: being the 79 z28 only has 175 HP stock (i forget the torque) what would you start out with to bring the power up, but without dropping 10 grand into it. If you can give me some price ranges too i'd appreciate it.
-mike
Old Sep 14, 2003 | 01:48 AM
talos's Avatar
welcome dude....
well start off with the basic stuff, like exhaust.. get some headers and some good flowing tubes.
also intakes are pretty cheap. look at getting a new intake and carb. then start to dig in that engine, and get into the cam and heads... bottom end, and things like compression blow on those cars, so things like pistons would be a good thing later down on the road...
but like i said, basic stuff first... intake and exhaust.
Old Sep 14, 2003 | 01:51 AM
Freak's Avatar
headers - $125
good dual exaust - price will vary
Edelbrock RPM Air Gap intake manifold - $200 (i dont know for sure that it will fit under the stock hood, im sure someone here will chime in on that)
Carb, if you plan on driving it on the street, IMO you cant beat the Edelbrock. they run about 200-275 bucks
while not a power increasing mod, a steeper gear ratio is a great mod. if your gears are under a 3.23 to 1 ratio i would DEFINETLY upgrade this can run from 250 to 750 depending on if you install them and what brands/ratio you go with
Old Sep 14, 2003 | 10:37 AM
Erik's Avatar
Classic Tech Moderator
The first thing to do is get a set of headers, convert to true dual exhaust and a pair of performance mufflers. Not only will you get a noticable improvement in performance, it will sound a hell of alot better too You could just get mufflers or headers, but it will be cheaper to do the whole thing at once.
If your car doesn't have posi, get it next.
Next would be an aluminum intake manifold such as the edelbrock performer and an edelbrock 650 carb with an electric choke. With the manifold/carb swap you'll also need a new air cleaner assembly, so you might as well get a K&N drop base. Clearance will be very tight so you'll probably need the shortest filter available. The throttle linkage will also become an issue, so expect to buy an aftermarket one.
The intake/carb swap is something you can do yourself, even if you've never done anything like it, so grab a haynes/chilton manual and dig in!
Next would be a cam/heads swap. Vortec heads are inexpensive and damn good. Combined with the right cam and you'll easily be making 350hp at the crank, or about 270 at the wheels and you'll be running mid-high 13's at a little over 100mph.
Old Sep 14, 2003 | 11:24 AM
xItsMike's Avatar
"convert to true dual exhaust"
how is this opposed to the dual exhaust it has now.
As far as the mufflers and headers go, this is pretty basic but what brands do you suggest.
I had mac cold air intake on my last car, I can swap it to this one - would this be a good choice for it?
Is it posi rwd or not? someone must know, i haven't lit them up yet. I assumed it was though. How much would it cost to convert to it if its not.
Old Sep 14, 2003 | 11:34 AM
xItsMike's Avatar
oh yea, and what would be the "right cams" to go with vortec heads, and whats are the gear ratio's to choose from and which being a better choice.
-thanks
Old Sep 14, 2003 | 10:01 PM
xItsMike's Avatar
not to be annoying but
::bump::
Old Sep 14, 2003 | 11:33 PM
Erik's Avatar
In stock form the exhaust system begins with a pair of heavy cast iron exhaust manifolds. The exhaust is then carried by a 'y-pipe', which joins the two exhaust paths into one. Shortly before the exhaust exits your vehicle, it is split again into two pipes. A true dual exhaust has 1 pipe for each manifold/header. Crawl under your car and have a look, you'll see what I mean.
For a gear ratio, 3.42:1 works quite nicely for a street driven car.
Your car has just one camshaft. As for a suitable one for vortec heads, there are much more knowledgable guys out there than me, so I'll let someone else take that one
For mufflers, it really depends on the sound you like... I have Flowmasters on my car, and like them. Other people swear by Dynomax.
The easiest way to tell if you have posi or not is to mash the gas and leave a little rubber on the road. It's also the most fun
Your Mac cold air intake won't work on your 'new' ride. Removing the rubber seal at the cowl (between hood and winshield) might get a little more cold air into your engine.
I don't know the cost of converting to posi. If you do get the conversion done, budget a little extra money incase you need new wheel bearings, and or axels.
Old Sep 14, 2003 | 11:44 PM
Freak's Avatar
well, the "right" cam and gears are kinda dependent on you and what you are doing with the car. if its your daily driver, then you might not want to get too wild with it. but what one person calls way too much another calls just enough.
what do you plan on doing? driver? drag car? weekend toy? whats your budget? do you drive lots of highway? only city?
one thing i have learned over the years, is that the keys to being happy with any engine you put together, is to A) be realistic with your goals (ie, dont build a hard core drag car and expect it to be easy to live with on a daily basis, or build a good driver and expect it to run 8's) and B) match the components you get with each other. (for example dont take an intake made for super high RPM and match it with a tiny cam made for low RPM) The Edelbrock packages are a very good way to do that for the beginner. Holley makes a couple of packages also. research is the best way to determine the best set up for your tates and use
easy way to do this on an engine already in a car, is to get a plan together, and map out what you want to do before you get anything, and dont stray from the plan. this way, in the end, youll have a good matched package, even if along the way you dont have the optimal setup. (of course if you plan to stratch the build out a bit, new parts will pop up, and may fit your plan better than what you had originaly intended to use)
Old Sep 14, 2003 | 11:49 PM
Freak's Avatar
oh, just to add, vortech heads are limited in cam lift to .480 inch lift cams. dont get one any higher than that unless you get the heads modified. I know some places sell them set up for higher lifts....
Old Sep 15, 2003 | 12:56 PM
1979Z28's Avatar
Greetings and welcome to the board
Since my car was stock not too long ago, I can give a little advice on what to do.
As was mentioned, you'll want to upgrade the exhaust. Personally, I prefer flowmaster, but others disagree. *shrugs*
Other things you can do, is upgrade to headers, the intake manifold, and do some suspension things.
Now, since your car is a Z28, you already have a posi rear-end, unless some nitwit specially ordered it from the factory WITHOUT it. All Z's came with posi.
For headers, the market is a wide place, but I've got Hedman headers. Picked them up off of a club member, so I can't give you any info on them.
Right now, I'm still running my stock intake manifold but I'm going to be upgrading to an Edelbrock Performer. The one that goes from idle to 5500 RPM.
Anyways, get some pictures taken! Can't wait to see it. Though our cars were rated at 170-180 hp, it doesn't mean they'll put out anywhere close to it. Wanna see what I mean?
http://camaroz28.cardomain.com/id/1979camaro
133 hp... *dies*
That's before the engine blew up on me and I had to swap in another 350 though. Hopefully I'll get a dyno sheet on my new stuff in a few weeks
Ah well, get pics up!@
Old Sep 15, 2003 | 04:36 PM
406TA's Avatar
How many miles are on the motor? Does it smoke? I would assess the bottom end of the motor before going crazy with Vortec heads, new cam etc. If the engine is still strong then the head swap, intake-carb, cam, exhaust would give you alot more power. However, if the engine is tired (smokes, little power etc) then a rebuild ($$$) will be necessary. Has it been tuned lately (cap, wires, plugs etc.)??
BTW, if you go with the Vortec heads I think Scoggin-Dickey sells the Vortec package (heads, rocker arms, intake manifold etc.) for around $750. Summit/Jegs sell standard 1 5-8"" Hedman headers for around $120. A good dual exhaust (custom) system (2.5") w/ an H or X pipe will cost btw. $400-800 (at least it's around that range here in RI). I like Holley carbs, a Holley 600 (vac. sec) would work well. If you have a 3.42 posi rearend then don't change it (like Erik said it's a great all around street ratio). A good cam for the Vortecs would be the Comp. Cams XE262 or the 268H (Hi-Energy).
Good luck w/ it!!
Old Sep 15, 2003 | 07:16 PM
xItsMike's Avatar
thanks guys, the suggestions were a lot of help. I basically wanted some good names and to know what not to do, which is what i got. I did some research on some different brands and I think i came up with something of a plan.
I think ill be starting off with :
-The true dual exhaust system, ill figure out which brand at the shop
-Edelbrock Performer Air-Gap (Idle-5500 RPM)
-Edelbrock Performer RPM Cam
Then:
-Headers (not sure which yet)
-Edelbrock Thunder Series AVS 650cfm Carburetor w/ electric choke
-K&N Air Filter (the reuseable ones i had one on my stang) and assembly
Ill be happy with this for a while and then l start digging in the engine more one day when i have more money and time.
By the way, yea i lit them up earlier today to see if it was posi n sure enough, i just dont like to do it on a new car dont ask me why (as if the tires will blow out the first time i decide to).
Oh and I bought it with only 60k miles on engine, it was rebuilt I think like 12 years ago by the original owner who is my friends uncle, who then only used it as a weekend car during summer until he gave it to my friend's brother 6 months ago, and now i bought it for 2k. I thought it was a great deal being everything looks close to immaculate interior and exterior -wise. I did a compression test on the engine before I bought it and everything was good.
And I do plan on using it like an everyday car, Im not going crazy to the point im getting horrible mpg and my engine is being beaten on, but just wanna give it a little more power than the 175 measly horses to go along with its strong look and name.
thanks guys.
Old Sep 15, 2003 | 07:19 PM
xItsMike's Avatar
oh yea, one other thing i wanted to ask
whats the point that you have too much power for the stock tranny and anything else that might be affected by added power.
Old Sep 15, 2003 | 09:54 PM
RoadRnnr69's Avatar
I would try the Edelbrock heads, I think they are the best HP for the money. Headers, intake and cam next.
