Painting Block Inside
TimChiaretto
09-12-2003, 08:00 PM
Is it still accepted practice to paint the valley area of a block? If so can someone recommend a good paint to use.
dave1w41
09-13-2003, 01:50 AM
It isn't necessary on an aluminum block LS1 but if you are painting the inside of an engine block, - you should get Glyptal paint. BUT, make sure the engine block is clean and totally free of oil before you attempt to paint the inside of it....http://www.eastwoodco.com/email/default.asp?T1=46001ZP&SRCCODE=O1KW818
