VINCELEE123
09-12-2003, 02:07 PM
ok ive got a 96 formula for sale, as of right now it doesnt run.
It has a 355 forged pistons,magnaflexd shoppend rods, nodular iron crank, nitrous rings, all new bearings,freeze plugs arp rod bolts. It has a comp 306 cam, coated hooker lts, stock heads, ported lt1 intake, 24lb svo injectors, pcm programmed for cam and stage II heads, new distributor, new plugs, tayor OVC wires
the transmission was built for nitrous, completely redone, new everything and a matching 2800 nitrous convertor
the engine and tranny has less than 200 miles on them.
the problems with the car are, the fuel rail is broke, you would need a new one, cam was installed one tooth off, it would need to be pulled and re installed, the car has no roller rockers right now, and it needs a cold air kit and a y pipe for the longtubes
this is what it would need
150$ for gasket
50$ for fuel rail
100$ for used cold air kit
169$ for ypipe
150$ for good rockers
car also has a new battery, harden pushrods,guild plates,air foil,
thats about it. Red T-top, gray cloth, factory cd, power everything,
4000$
Vince
150$ for gasket
50$ for fuel rail
169$ for ypipe
4000$
Vince
