KwikistZ
09-11-2003, 06:20 PM
I'm looking into trickin the stereo in my S-10 out. I was wonderin how this tri-way amp stuff works. And how much RMS power is being put out when in this 'tri-way' mode. This is the amp I'm talking about... http://www.crutchfield.com/cgi-bin/S-osqfRc2mpJ5/ProdView.asp?s=0&c=3&g=120&I=206KX6004&o=m&a=1&cc=01&avf=Y I'm set on kicker so don't try and change my mind:D
And these are the subs I want to get(2) http://www.crutchfield.com/cgi-bin/S-osqfRc2mpJ5/ProdView.asp?s=0&c=10&g=67500&I=2063C8VR2&o=m&a=1&cc=01&avf=Y Should I get dual 2-ohm, or dual 4-ohm?
I was wondering if I had that amp in tri-way, if I could power 2 subs and then use the 3rd channel for 2 front speakers. I'm going to have those 2 subs behind my seats(reg cab)and then get those kick panel kits and stick 6 1/2's in them with tweeters. Then just get rid of the factory speakers, and get creative covering up where they used to be. What do you guys think? Thanks!
:metal:
firebirdude
09-11-2003, 08:05 PM
For some reason the links aren't working for me. But I think I can help anyway. I assume that you are looking at a Kicker 4-channel amp? And you are looking to run it in 3-channel mode? Ok, first, you will want the dual 4 ohm version of the subs. Wire the voice coils together in parallel and then wire the subs together in series. This will present your amp with a 4 ohm load. Which is what's need when you bridge two channels of an amp together. And you have your set-up backwards. Run your two front speakers of the two front channels on the amp. Then use the bridged rear channels for the subs. Lemme know if you have any questions.:)
KwikistZ
09-11-2003, 08:10 PM
The amp says...
150 watts x 4 at 2 ohms
300 watts x 2 in bridged mode
How many watts will be shot at the subs, and then the front channels? They are upto 200w RMS subs and I wanted to have all that 200. Thanks again!
Sketchy:metal:
firebirdude
09-11-2003, 08:31 PM
Originally posted by KwikistZ
The amp says...
Sketchy:metal:
You front speakers will be getting 75W each and the subs will get 300W
RallyRedTexan
09-15-2003, 10:16 PM
You'll be getting 75Wx2 for the front channels and 300Wx1 bridged into 4ohms for the sub setup. You'll want your subs to equal 4 ohms when all connected. Don't be so closed minded you'll miss alot of great products :(. And Don't get 8" subs, those are for doors :). I personally would go with Alpine Type-S for that price, I'm just not impressed with the new Kicker subs. Both of those brands require a bit too much space IMO for a truck. If you can manage a bit of extra scratch I'd go with (2) eDesign 10K.44. They are definately superior to both of those that have been mentioned and they work stellar in a .5 cu. ft. enclosure, which will prevent alot of headaches for you.
But both requireThe amps are still a great priduct if not a little BIG and bulky. You could run two subs with 4ohm Dual voice coils and wire them in a series/parrallel arangement.
And for the love of all that is holy don't buy from Crutchfield. You can get much better prices.
