Need Help!
Pewter99_Trans
09-11-2003, 03:03 PM
I am totally clueless when it comes to speakers! The stock monsoon sounds like **** with them rattling from me blowing em i think and I want to upgrade all the factory speakers, but i need you guys to tell me what speaker to go with. I dont have to have the top of the line but on a scale of 1 to ten id said i want a speaker thats around an 8. Please help me out.
firebirdude
09-11-2003, 08:33 PM
You can't just replace the speakers with the monsoon system. They will need an aftermarket amp or head unit to power them. How much you looking to spend?
Pewter99_Trans
09-11-2003, 09:15 PM
I dont want to just replace the crappy monsson system i have now. I will spend as much as i need to to get it done right. If 1 was the crappiest parts you could use and ten is top of the l line i want to go with something around an 8. So anything around that quality to replace stock speakers.
firebirdude
09-12-2003, 01:23 AM
Well, if money doesn't really matter. How about replacing everything? That's what it takes. The monsoon amp is total cr@p, and as you already know, the stock speakers are just as bad. How about a new head unit, a nice set of components up front and a single 10" powered by a 4-channel amp? Quality gear of all of this would probably cost around $750 not including wiring or installation. I suggest you install it yourself. It's very easy and we can talk you through each step if need be. Lemme know what you think. :)
Pewter99_Trans
09-12-2003, 01:20 PM
I want to replce all the factory speakers in the monsoon with good aftermakret equiptment. I am going to be getting a deck with 45x4 watts. So what speakers,sizes, and amp would be a good setup?
firebirdude
09-12-2003, 08:43 PM
Check out this (http://www.ls1.com/forums/showthread.php?s=&threadid=374778) topic I answered earlier. That was a pretty cheap system. If you can afford better, then I suggest spending it on the components. The access line is great, but there is better!:D What headunit are you buying? Oh, and you won't need the PAC OEM-1 or anything with your system since you are replacing the factory headunit.
Rogue Leader
09-14-2003, 05:24 PM
Are you SURE about not being able to replace the factory speakers... while yes the monsoon speakers are DVC, they are 4 ohms at each coil, so you can just cut the harness off the speaker and use 1 end of it to power a normal SVC speaker. in the case of the fronts, you can just connect both harness wires to each seperate component on the aftermarket speaker if you dont mind cutting a little. It does work and really doesnt sound bad.
Btw if anyone happens to have the specs on the power output of the factory monsoon Amp, I would be very interested to see them.
