rrapp00
09-09-2003, 09:54 PM
What would the best intake be for my 87 iroc 350 tpi either beefing up my tpi system or getting a stealth ram , super ram , or mini ram stuff like that you know which would be better?
What is the best intake?rrapp00 09-09-2003, 09:54 PM What would the best intake be for my 87 iroc 350 tpi either beefing up my tpi system or getting a stealth ram , super ram , or mini ram stuff like that you know which would be better? doug791 09-09-2003, 10:20 PM i do believe the mini-ram is the top performer and for 1300 dollars with fuel rail it better be! aklim 09-10-2003, 05:16 PM I like the Superram setup which allows you to reuse your fuel rail and exposes the schraeder valve to check fuel pressure. Plus the fuel pressure regulator is easy to get to if you have to change it or adjust it if you get the AFPR. Not sure about the others. rrapp00 09-11-2003, 03:30 PM So a beefed up tpi system isnt that good Black6SpdTA 09-11-2003, 03:41 PM Originally posted by rrapp00 So a beefed up tpi system isnt that good It can be good. Port the gahunas out of it. There's no way it'll be AS good as one of the "Ram's" but definitely will be the most cost-efficient way. -Rippin aklim 09-11-2003, 04:47 PM Beefed up as how? Port and polish? Total change? What are you trying to achieve and what kind of money to spend? What future mods do you plan? rrapp00 09-11-2003, 04:55 PM Originally posted by aklim Beefed up as how? Port and polish? Total change? What are you trying to achieve and what kind of money to spend? What future mods do you plan? Buying a whole new tpi kit for thats supposed to add horse but i figured buying one of the rams would be better. And i plan on rebuilding tranny or buying a diff one,383, different rear axle gear possibly super charger if i ever get that much money. aklim 09-11-2003, 05:05 PM I have been very happy with my Superram. I would rebuild your 700 if that is what you have. That will stand up to the 383 if done right and you will have overdrive which is nice. Before you go with the SC, I would do heads and cams first. Something like AFR 190s or 195s will be good. Rage 09-11-2003, 08:31 PM You can buy an LT1 for really cheap, and they're pretty good. www.lt1intake.com check that out, $400 gets you ready to bolt it in. rrapp00 09-11-2003, 09:50 PM Originally posted by aklim I have been very happy with my Superram. I would rebuild your 700 if that is what you have. That will stand up to the 383 if done right and you will have overdrive which is nice. Before you go with the SC, I would do heads and cams first. Something like AFR 190s or 195s will be good. Yea i was thinking bout just rebuilding my 350 with a 10 to 1 comprassion rate and adding heads and buff cam and all that stuff up but id say 383 would be better. rrapp00 09-11-2003, 09:53 PM Originally posted by Rage You can buy an LT1 for really cheap, and they're pretty good. www.lt1intake.com check that out, $400 gets you ready to bolt it in. Wow tahst awesome but i thought the lt1 intake and tpi were pretty much the same performance wise maybe not? doug791 09-11-2003, 09:55 PM i do believe the lt1 intake is based off of the mini-ram and has much better performance kandied91z 09-11-2003, 10:17 PM my vote is for the miniram or superram depending on the needs and budget. i have a miniram so i should be biased but i don't think too highly of tpis at all so i wouldn't get it again. for ease of use and power the miniram works very very well though. doug791 09-11-2003, 10:36 PM Originally posted by kandied91z my vote is for the miniram or superram depending on the needs and budget. i have a miniram so i should be biased but i don't think too highly of tpis at all so i wouldn't get it again. for ease of use and power the miniram works very very well though. what problems have you had with tpis??? DC89IROC-Z 09-11-2003, 11:27 PM What are the prices on all these? kandied91z 09-12-2003, 12:29 AM everything under the sun.....another thread another time. :) rrapp00 09-12-2003, 01:39 PM How much is a miniram and where can i find it and how easy is it to install doug791 09-12-2003, 03:35 PM www.tpis.com around 1300 dollars with fuel rail i do believe it is a straight bolt on Damen 09-12-2003, 03:53 PM Now, my understand is that the LT1 intake (at least, the one linked to) and the super ram are NOT emissions legal. Is this correct? Are any of these alternate intakes emissions legal? For those of us in states with emissions laws, this sort of thing is important ;) kandied91z 09-12-2003, 04:00 PM obviously an lt1 intake should be since it is on an lt1. however the superram/miniram are not. Black6SpdTA 09-12-2003, 04:00 PM I'm 100% sure the Stealth Ram, TPIS Bigmouth and SDPC Vortec intakes are all street legal. I would imagine the LT1 one is (same intake as the 4th gens). As for the SuperRam, I'm not sure. -Rippin Damen 09-12-2003, 04:04 PM My comment for the LT1 was based on the FAQ on that site, which said that it wasnt emissions legal. doug791 09-12-2003, 04:08 PM meh just about everything is non emissions legal....whatever here i just gotta pass a sniffer so as long as i can do that its all good =) and if not i have a couple hundred bucks layin around somewhere Damen 09-12-2003, 04:11 PM So, say between the Stealth Ram and the LT1 Intake which would you guys reccomend? (sorry for kinda hijacking this thread, lol) -Damen Zepher 09-12-2003, 05:56 PM I am going to put the Stealth Ram on my 88 formula in the near future. | ||
