iroczinoz
09-09-2003, 07:49 AM
I have just welded together my LCA relocation brackets going by some good plans I have.
The only thing that needs to be done is to drill the holes. But I am unsure what size to drill the holes. The bolt where the stock LCA goes through on the plan it says 16mm or (5/8")
But then on the 2 new holes you drill out to mount the LCA to they are described as (1/2") or 13mm. So I dont understand why there are different sizes in holes when you are still mounting the same LCA and that has not changed.
Does anyone know what bolt size is used on 3rd gen camaros that hold the LCA?
Any help much appreciated!!
