stjames69 07-27-2002, 10:06 PM Has anyone here used N2o on their 98 + v6 fbody? If so, what setup you running? What strength? Any concerns that are particular to our cars?
Cheers
Ryan
1998 3.8 Camaro Black
- Y87 Package
- 5 Speed T-tops
- Flowmaster Exhaust
- Jet Performance Stage2
- Accel 9000+ wires
- 160 Stat
- 18x9 Mille Miglia 11-2 Wheels with 235/40z18 front, 275/35z18 Rear Yokohama AVS Sport Rubbers
- Xenon Body Kit
- K & N Filter
- Autometer Pro Shift
mm2harrell 07-27-2002, 11:02 PM I'm spraying my 3800 but it's a 97. I use a zex 100 horse dry kit with the nozzle about 6 inches in front of the throttle. the only thing i've had to change so far is the clutch.
Fear the raven.
nikkev 07-27-2002, 11:52 PM The main thing to remember about nitrous is that you need to make sure you never lose your fuel supply.Nitrous minus fuel equals BOOM! http://web.camaross.com/bb/eek.gif So either run a wet kit or make sure your fuel system is up to par.I ran a 100hp shot on my '95 3.4 and never had any problems with that shot.Also you never want to shoot the juice at anything less than full throttle.So a basic kit should include at least:
-Fuel pressure safety switch
-Full throttle switch
There are a lot of extras you could get but those main safety items should be there.Good luck.You also might want to check out the nitrous forum at www.firebirdv6.com (http://www.firebirdv6.com) and have fun!
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,IAT Tricker,TB Bypass,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics (http://photos.yahoo.com/bc/nikkev1/lst?.dir=/New+Camaro&.view=t)
shortdog273 07-28-2002, 04:21 PM 100 shot on a 3.4 is alot
2000 BLACK FIREBIRD 3.8 A4 (http://www.nobispro.com/carpics/pics/FBird.jpg), (Stock 3.42 Gears, LSD, W68 Pkg), 160* Powerstat, Whisper CAI & Lid, K&N Filter, 3 Catco Highflow Cat (http://store.summitracing.com/default.asp?target=search.asp%3FType%3Dbysummitpar t%26Part%3DCTO-6007%26Search.x%3D1%26SearchType%3DBoth), 3in. S Pipe (http://www.jcwhitney.com/item.jhtml?ITEMID=4043&BQ=jcw2), 2.75" Dynomax Catback, Sprint Springs, BMR STB, LCAs & Brackets.
MOFBA (http://www.mofba.net/forums/)/FASTLOUIS (http://www.fastlouis.com) Member... 1/4 Time: (http://timeslips.firebirdv6.com/timeslips/darrian_hickman.jpg) 14.981 @ 89.66 MPH
nikkev 07-28-2002, 05:31 PM <font face="Verdana, Arial" size="2">Originally posted by shortdog273:
</font>
Yeah,but she took it like a champ! http://web.camaross.com/bb/biggrin.gif I had my kit on there for over a year and Tim LeGros had a 90hp shot on his '95 3.4 for right around 3 years I think.Neither of us had any problems from using that high of a shot.The 3.4 has a very strong bottom end,the only thing that's weak is the pistons themselves.And like I said above,throw enough fuel in with the nitrous and you should be OK.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
[url="http://www.corvettemuseum.com/registration/f-body/agenda.shtml"]Camaro/Firebird Birthday Bash (]Pics[/url)
shortdog273 07-28-2002, 05:53 PM That's pretty good. I was told anything under a 100 shot should use the dry kit. I'm looking into it.
2000 BLACK FIREBIRD 3.8 A4 (http://www.nobispro.com/carpics/pics/FBird.jpg) (Stock 3.42 Gears & LSD), 160* Hypertech Powerstat, Whisper CAI & Lid, K&N Filter, 3 Catco Highflow Cat (http://store.summitracing.com/default.asp?target=search.asp%3FType%3Dbysummitpar t%26Part%3DCTO-6007%26Search.x%3D1%26SearchType%3DBoth), 3in. S Pipe (http://www.jcwhitney.com/item.jhtml?ITEMID=4043&BQ=jcw2), 2.75" Dynomax Catback, Sprint Springs, BMR STB, LCAs & Brackets.
nikkev 07-28-2002, 06:07 PM <font face="Verdana, Arial" size="2">Originally posted by shortdog273:
</font>
Are you sure they said should or that it would be safe?It will never hurt to run a wet kit,just make sure the nozzle is jetted right for the amount of nitrous you are using.If the fuel injectors lock up on a wet kit,the car will be OK.If the fuel injectors lock up on a dry kit *BOOM*. http://web.camaross.com/bb/eek.gif It will not hurt the motor any if the nitrous solenoid locks up and you only spray fuel into the intake,the car will just run a bit rich.That's why I always suggest a wet kit to nitrous users.I am getting another one in January when I get back from Germany to go on the Z.Later.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Camaro/Firebird Birthday Bash (http://www.corvettemuseum.com/registration/f-body/agenda.shtml)
nikkev 07-28-2002, 06:09 PM Oh yeah:
IF YOU USE NITROUS YOU HAVE THE POTENTIAL TO DAMAGE YOUR MOTOR!! Please don't shoot a 150hp shot and then say that I told you it was OK.Please take my advice at your own risk.
Kevin
mm2harrell 07-28-2002, 09:52 PM i would use the dry kit anyway. wet kits have more of a tendancy to cause intake manifold backfire.
Fear the raven.
