3rd gear "disappears" during WOT 2-3 shifts
Old Sep 8, 2003 | 06:31 PM
trax's Avatar
I've been driving stick for about a month and have gotten pretty decent, but this didn't seem normal. I took the car to the track last Saturday for the first time after the T56 conversion and had some problems shifting into 3rd gear whenever the car was at WOT.
I could shift the car from 2nd into neutral, but I couldn't push it up into 3rd. If I let the car spin down a little the gear will magically reappear and I can push the shifter up into gear.
Keep in mind this isn't powershifting, just WOT up to the shift point (~6K on the stock tach) let off the gas for a split second, clutch and shift.
What confuses me is that the tranny doesn't have this problem if I'm not punching it. I can have the throttle about 90% of the way down as I accelerate up to my shift point and still shift it without any problems, but that extra little bit into WOT seems to cause problems. Any ideas?
Old Sep 8, 2003 | 11:24 PM
AL SS590 M6's Avatar
Moderator
Your clutch isn't disengaging at high revs. It goes in after the ravs fall because they are low enough to match the driveline.
Probably a hydraulic problem.
Old Sep 10, 2003 | 08:23 PM
1.8ttolt1's Avatar
mine is doing the same thing, i was just gonna post this question. what is the fix?
Old Sep 10, 2003 | 11:52 PM
Moderator
Sometimes bleeding.
Usually a new master and/or slave.
Old Aug 26, 2004 | 01:24 PM
BlueRave's Avatar
Re: 3rd gear "disappears" during WOT 2-3 shifts
Did you find a solution to this problem? Anyone else experiencing the same thing?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
blac94Z
Jan 12, 2015 05:44 PM
Jul 4, 2005 05:00 PM
Rbain
Sep 4, 2002 12:35 PM
