Torque Arm Mount (T56 Swap)
Black6SpdTA
09-08-2003, 04:47 PM
I haven't yet started the install (shifter still hasn't arrived) but just learned I needed the Torque Arm mount from the 4th gen. Is there ANY way to reuse the T5 mount? Thanks
-Rippin
camaroz28racer2
09-08-2003, 08:49 PM
Yeah re use it by bolting it on, whoever said you needed a 4th gen mount is a moron, I think i saw who it was on tgo, someone who keeps posting mis-information.
mrr23
09-08-2003, 09:03 PM
well go to www.spohn.net he sells the proper crossmember for the conversion. you can use the 4th gen one but have to cut and weld it to a different angle to fit.
doug791
09-08-2003, 09:19 PM
Originally posted by mrr23
well go to www.spohn.net he sells the proper crossmember for the conversion. you can use the 4th gen one but have to cut and weld it to a different angle to fit. wow i dont think that had any relevance to the topic at all :)
mrr23
09-08-2003, 09:21 PM
yep you are correct. missed the torque arm part didn't I? i was obviously thinking of the wrong part.
TheGreatJ
09-09-2003, 01:42 PM
It's somewhat relevant.....if you get the Spohn crossmember and torque arm you don't need the factory T-56 torque arm mount.
I've heard from a couple of guys that the T-5 mount will bolt onto the T-56, but I don't know if this is accurate because I haven't had any dealings with a T-5 mount. My car started life with a 700-R4.
Black6SpdTA
09-09-2003, 03:48 PM
Could you get just the crossmember then later get the torque arm? The picture on the site makes it appear one solid piece?
-Rippin
camaroz28racer2
09-09-2003, 05:31 PM
The T5 mount bolts to the T56, end of story, dont care what you want to guess at, you dont need a 4th gen torque arm or mount or whatever, dont wanna hear it, stock T56 bellhousing, regular sbc, use any of the crossmembers designed for the OEM T56, the normal spohn crossmember does not come setup for the tubular torque arm, you may be able to buy that from them and then the arm later however im not sure if they will do that.
TheGreatJ
09-09-2003, 06:18 PM
Yeah you'll have to ask Steve about that one. You get the crossmember when you buy the torque arm usually....I'm not sure if he'll sell them seperately. I kinda doubt it but you won't know unless you ask.
IrocinthatZ
09-10-2003, 08:19 PM
Ok well im not a moron and i had to get a torque arm mount from a 4th gen to get it to fit on my iroc....i did have a 700r4 though.
