GMH94Z28 07-19-2002, 09:47 AM Is there any difference in a 1994 Z28 chassis and a 1994 V6 chassis? I need a camaro chassis that i can put my LT1 in. Thanks
1994 Camaro Z28 A4 Hpp, msd box and blaster coil, 8.5 msd plug wires, Moroso CAI, Airfoil, Flowmaster Exhaust.
nikkev 07-19-2002, 06:49 PM The V6 and V8 chasis is exactly the same.The only differences between the two (other than the motor) are:
-Tranny bellhousing
-Springs/shocks
-Motor mounts
-Driveshaft
-Posi rear and disc brakes
-Speedometer
Other than that,I think everything else is the same.So are you looking for a new body to put your LT1 in?Good luck.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics (http://photos.yahoo.com/bc/nikkev1/lst?.dir=/New+Camaro&.view=t)
MustangEater82 07-19-2002, 07:48 PM sway bars are smaller too.
you can get an lt1 driveshaft for about $25
take off shocks and springs form SLP(if you want to deal with SLP)
sway bars are cheap maybe $40 for both front and rear.
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Splitfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys
Lightest Weight W/out driver: 3160
15.696@86.22 with a 2.214 60'!
Best R/T .507
Best 60' 2.106
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
AIM: MustangEater82
nikkev 07-20-2002, 07:46 PM <font face="Verdana, Arial" size="2">Originally posted by MustangEater82:
</font>
The rear sway-bar is the same.I think only the front is different.
Kevin
Edit:That's one advantage the 3.4 has over the the 3.8 http://web.camaross.com/bb/biggrin.gif
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
[This message has been edited by nikkev (edited July 20, 2002).]
GMH94Z28 07-23-2002, 08:49 AM I am just looking for a 94 camaro chassis to to pull the motor out of my wrecked 94 Z28 get back it back on the road again.
Thanks for the replys
MustangEater82 07-24-2002, 03:04 PM <font face="Verdana, Arial" size="2">Originally posted by GMH94Z28:
</font>
i am pretty sure you would nto have much trouble any body 94-96.
93 might be possible too but a 97 the interios gets different.
Best R/T .507
Best 60' 2.106
AIM: MustangEater82
