high flow cat..
fiz
07-18-2002, 10:04 PM
I have a few questions
first off, is High Flow a brand name, or just a description of the cat?
second, I have a borla cat back exhaust on my v6 bird, how much of a difference will the sound be with a high flow cat, and how much performance gain if any?
third, how much do they usually cost, and where can I get one?
thanks guys
redcamaro9090
07-18-2002, 11:55 PM
High-flow isn't a name, it's just a cat. that has higher flow http://web.camaross.com/bb/biggrin.gif . This website has high-flow cats. www.thunderracing.com (http://www.thunderracing.com)
zlightning
07-19-2002, 12:20 AM
I saw test flows on high flow cats and random technology came out on top followed by car sound. I only remember those two.
MustangEater82
07-19-2002, 02:29 AM
going the budget route CATCO has the cheaper route and i have heard good things.
I think they are about $120 cheaper then reandom techs cats.
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Splitfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys
Lightest Weight W/out driver: 3160
15.696@86.22 with a 2.214 60'!
Best R/T .507
Best 60' 2.106
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
AIM: MustangEater82
fiz
07-19-2002, 07:15 PM
what will the difference in sound be liek with a catco than with my stock cat? i have a borla catback 3" exhaust with one plate up from closed
shortdog273
07-19-2002, 07:22 PM
<font face="Verdana, Arial" size="2">Originally posted by fiz:
what will the difference in sound be liek with a catco than with my stock cat? i have a borla catback 3" exhaust with one plate up from closed</font>
Deeper and louder. My dynomax sounds like the flows I had at idle due to the highflow cat.
2000 BLACK FIREBIRD 3.8 A4 (http://www.nobispro.com/carpics/pics/FBird.jpg), (Stock 3.42 Gears, LSD, W68 Pkg), 160* Powerstat, Whisper Ram Air & Lid, K&N Filter, Catco Highflow Cat (http://store.summitracing.com/default.asp?target=search.asp%3FType%3Dbysummitpar t%26Part%3DCTO-6007%26Search.x%3D1%26SearchType%3DBoth), 3in. S Pipe (http://www.jcwhitney.com/item.jhtml?ITEMID=4043&BQ=jcw2), 2.75" Dynomax Catback, Sprint Springs, BMR STB, LCAs & Brackets, 18" Mondera Wheels
MOFBA (http://www.mofba.net/forums/)/FASTLOUIS (http://www.fastlouis.com/cgi-bin/yabb/YaBB.cgi) Member... 1/4 Time: (http://timeslips.firebirdv6.com/timeslips/darrian_hickman.jpg) 14.981 @ 89.66 MPH
