IROC350
09-07-2003, 12:10 PM
i just got my tranny and shifter hooked up in the car, but when i start it the fans won't kick on...AT ALL! the car got to 250 degrees yesterday while a friend and i tested the tranny. i can't find the problem, any ideas?
What all have you checked regarding the fans?
Shaun 90 Iroc
09-07-2003, 01:09 PM
The fans won't kick on unless the car goes above a certain temp. The second fan will come on with the A/C though. To test if all the connections and fan motors are good. You can connect the top right two of the ALDL, i gotta special little piece, but i have used a paperclip to do that. Once the car is just in start mode.. but not started. Both fans should kick on. You will beable to see if one or both are not working or malfunctioning. My car started gettting hotter than usual and i did this and my primary fan would try and start and made some not so good sounds and just kinda died off.. So i went to GM and they just wanted $30-40 for a new fan motor. It could also be the relays though, which depending on the year can be located in different spots.
lordmetalz28
09-07-2003, 01:13 PM
best thing to do first would be process of elimination. check your fusible link. next jump your fan straight to the battery see if it works at all. then you can proceed with you relays so on so forth and temp sensor.
IROC350
09-07-2003, 02:58 PM
well, code 15 is being set off which deals with the temp. sending unit. the fans wouldn't cut on at all. the engine got to above 250 degrees and still nothing. there's not a wire going into the temp. sending unit and i think that may be it. but i cant find the wire...
IROC350
09-07-2003, 03:02 PM
where does the wire originate from?? that may help in my search:)
IROC350
09-07-2003, 04:16 PM
there was a blown fuse!!! problem is solved and after a year, the IROC is back on the road!
YEEHAWWW:D :bow:
lordmetalz28
09-07-2003, 09:24 PM
i know i just didnt see a post on radiator fans by pro lets not start again pro you got cut down bad last time because you have no idea what your doing. way to go with the fuse good luck with your car
