Ferocity02 09-07-2003, 01:32 AM I finally figured out that the middle speaker on the passenger side has gone out. I need something halfway decent to replace it that won't cost an arm and a leg. Any suggestions on what to get and where to get it. Oh, and are the middle speakers only supposed to put out bass? Thanks.
fiftyonefifty 09-09-2003, 02:43 AM JL Audio 6w0. Technically it's supposed to have a box, but using it in the mid section of a camaro should sound good, and it would probably increase your bass pretty well in the car since it's a subwoofer.
other than that, you might check eBay for a good deal on some MB quart mids
firebirdude 09-09-2003, 01:24 PM Originally posted by Ferocity02
Oh, and are the middle speakers only supposed to put out bass? This makes me think that you have the monsoon system?
moonpetal38 09-09-2003, 06:13 PM If it is a monsoon system, won't this mean that speakers are needed with special requirements? Or get factory's. I ask this question because I have a passenger side speaker that rattles. I have been asking around town but get the same answer. Get factory's. I would like to get something better than factories but can't seem to get a straight answer about it.
firebirdude 09-09-2003, 06:59 PM Here's (http://www.ls1.com/forums/showthread.php?s=&threadid=48092) some good reading material.
moonpetal38 09-10-2003, 06:16 AM Thanks!
Ferocity02 09-11-2003, 02:03 AM So will a 6.5" 2ohm sub work, and not fugg up the rest of ym system? Are they hard to find? Will Best Buy or Circuit City have them? Thanks
camaroFl 09-17-2003, 03:16 PM I have same problem with my speakers they but I told you have to buy factories it suxs bad I wish somebody could help us this is bs only tied to factory crap speaker that can't even handle the power dammit wb if you can cya I need help! they cost 75 for the fronts dor speakers
firebirdude 09-17-2003, 03:54 PM Image Dynamics makes a 2 ohm midbass speaker. But, as I've stated before, powering them with the stock amp is a federal offense.
camaroFl 09-17-2003, 03:58 PM Originally posted by firebirdude
Image Dynamics makes a 2 ohm midbass speaker. But, as I've stated before, powering them with the stock amp is a federal offense. no I need the door speakers
firebirdude 09-17-2003, 05:04 PM Originally posted by camaroFl
no I need the door speakers I was repling to Ferocity02......since this is his topic.:p But Image Dynamics also makes 2 ohm component systems as well.
Rogue Leader 09-17-2003, 10:22 PM Rockford fosgate makes the RFP4406 6.5 inch sub.... Im considering picking em up and trying em, they are SVC 4 ohm tho...
Ferocity02 09-21-2003, 12:05 AM What is the part number for the stock middle speaker? Thanks
Ferocity02 09-27-2003, 09:34 PM TTT
Coolformula 09-29-2003, 12:16 PM I have a aftermarkter HU, I don't see NO amp in my wheel while, so I assume somebody trahsed before I got teh car, my new HU is 4 ohms so I should be able to replace the speakers not without a promblem right???
firebirdude 09-29-2003, 12:45 PM Originally posted by Coolformula
I have a aftermarkter HU, I don't see NO amp in my wheel while, so I assume somebody trahsed before I got teh car, my new HU is 4 ohms so I should be able to replace the speakers not without a promblem right??? If you are bypassing the amp completely, you will have no problems.
