bigcarguy
09-02-2002, 10:58 PM
Alright, I need to know everything I can about my stock 77 305 2bbl heads. I have a 307 in my truck and have had severalpeople tell me that 305 heads on it would add a little power(higher comnpression, greater velocity thanks to smaller valves). So I need to know everything about these heads: Valve size, combustion chamber size, flow numbers if anyone knows, etc. If no one knows, then being pointed in the right direction would be appreciated.
BamaZ28
09-03-2002, 12:38 AM
You need to get the casting number from under the valve cover, between the springs. It will from 6 to 10 or so numbers long. Then go to
http://www.camaro1stgeneration.com/cam1stgen/codes/headcastings.html
and check em out. Good Luck
1981 Pontiac FB originally V6, converted to SBC (HEI), Performer RPM, Holley 750 Vac Sec., Chrome Dress up, True Duals
Damon
09-06-2002, 12:26 PM
If they're stock they'll be 58cc chambers (probably slightly larger in reality) with 1.74/1.50 valves. They are the worst possible 305 heads ever made. I have couple of sets of them. Email me and I'll get the numbers off mine and you can see if yours are the same. Later model "441" (or is it 414?) heads like used in the early-80s 305 HO use larger 1.84/1.50 valves and have better ports and chambers and will bolt right on. No stock 305 head is really very good, though.
TJS69
09-06-2002, 02:49 PM
It would be easier (IMHO) to swap in a 350 than to swap heads. At least more beneficial.
69 Camaro Z28 "clone" 327 AT
DAYTONA YELLOW WITH BLACK Z28 STRIPES
327 - "461" camel back heads. TRW,Edelbrock,Ultradyne,Hooker
TPI 700r4 automatic transmission
