custom high HP N20 pistons and custom rings
They were designed for my 900 hp 383, but the cash for the project fell thru. 500hp engine, 300 shot (min).
They need 1/16 1/16 3/16 Rings
Piston size 3.905
Piston weight 371g
Piston pin weight 118g
Compression Height is 1.055
Valve releifs -7cc
They will work the best with a 6.200 Rod and a 4.000 stroker crank, or a 6.400 rod and stock stroke crank. I suggest oliver rods.
Price list.
Pistons $580
H-13 pins (n20 pins, not statandard tool steel) $18.43 each
Pin fit and oil support rails $7.50 each
TOTAL $751.00
$650 shipped.
Custom made piston rings for those pistons
TOTAL SEAL MAX SEAL RINGS
Made for a 400 shot as well as N/A
$260
Buy both for $800 shipped
fatsix@comcast.net
BRE can set you up witha killer package
Piston size 3.905
Piston weight 371g
Valve releifs -7cc
Price list.
Pistons $580
TOTAL $751.00
$650 shipped.
$260
fatsix@comcast.net
ReznorZ28
Aug 27, 2002 03:53 PM
Brad122470
Aug 2, 2002 08:55 AM
