Shift tables 95 a4 3.23
djc485
09-04-2003, 03:13 PM
I recently had my car hooked up to a tuner cat to fix my speedometer. It turns out the gear setting was calibrated for a car with 2.73. After I changed the gears the shift tables were deleted and I had to estimate the shift points. I am pretty close but exact I hit the rev limiter if I give it to much gas to close to the redline. I am looking for the shift tables for a 95 a4 with 3.23's any response would be greatly appreciated.
Hotwire
09-04-2003, 09:05 PM
i have my stock lt1 file,
wot shift table:
1-2 36mph
2-3 73 mph
3-4 126 mph
hope this helps
djc485
09-04-2003, 11:04 PM
Thank you, do you possibly have the downshift points, or maybe the whole table? Thanks again!
xchief1320
09-05-2003, 02:03 AM
What about adding a stock BIN to the tuner so you can compare?
I have a stock 94 A4 323 Bin if that would help..It's not a 95 though.So i'm not sure if it will work..If you post your e-mail i'll be glad to send you the 94 BIN i have..
On my table it says WOT would be
upshift
1-2..36
2-3..73
3-4..126
downshift
2-1..31
3-2..67
4-3..118
Steve
djc485
09-05-2003, 03:09 PM
That would be a great refrence for me. If you could email it to djc485@cs.com when you get a chance I would be very greatful!
xchief1320
09-05-2003, 03:10 PM
You got mail...
Steve
shoebox
09-05-2003, 04:18 PM
Just posted in another thread, but here is a 1995 A4 3.23 bin file (http://csce.uark.edu/~jgbertr/rb/stock_tune_1995_A4_3.23.bin).
djc485
09-07-2003, 12:44 PM
I can not open either of those files. Do I need some type of special software?
xchief1320
09-07-2003, 01:16 PM
Are you saving them in your Tunercat folder?if not then it won't open them..
If your home PC "or whichever one you're online with" isn't the one with Tunercat on it you will need to save the BIN file on a 3 1/2" floppy or CD and then use that to save it on your laptop that has Tunercat on it..
I didn't have any trouble with the one shoebox posted..
Steve
djc485
09-07-2003, 07:32 PM
thank you ill do that
