T56 trans fluid?
rumair
09-02-2003, 10:05 AM
having never added trans fluid to the 6 speed i figured it might be a good idea to find out exactly what to use before i go dumping in the same ATF i use in the TH400. :)
anybody have any recommendations? i dropped about 1/2 quart out the back when i took the driveshaft out the other day. i figure the easiest way to add fluid is through the shifter, right?
red
09-02-2003, 11:23 AM
The T-56 does take ATF. I use synthetic. I do not know if you can add through the shifter. I have never tried it. I always have added fluid through the filler plug on the drivers side.
PatriotTA
09-02-2003, 12:19 PM
Yes, the T56 uses Dexron III ATF as stated on the sticker on the side. And yes, you can remove your shifter and add fluid through the top.
rumair
09-02-2003, 02:09 PM
thanks guys
Black6SpdTA
09-02-2003, 04:10 PM
Little off topic but, How many quarts does the T56 hold? Thanks
-Rippin
PatriotTA
09-02-2003, 04:19 PM
-Rippin
