Help with Zex kit
nutts 96 ws6
09-01-2003, 09:27 PM
Ok I have everything hooked up with a rpm window switch and I am pretty sure that everything is hooked up correctly. The problem is my friend told me that there should be a red light thats on when the box is on. But since the window switch is there it shouldt come on until 3000 - 5600 rpms. So I turned the ignition on to the car, pushed the throtlle all the way down and pushed the button. Then I started the car and pushed the throttle down and at 3 grand the green light flashes. Is it supposed to flash? Also there is not any nitrous that comes out. Any ideas?
Thanks.
lt1form
09-02-2003, 03:27 AM
A ZEX nitrous kit has to "learn" your TPS signal, If I remember from installing my friends you have to hook it up then a certain color comes on and someone has to be in the car and pushes the accelerator down and up a few times with the key on.
And if I remember right the light on the main ZEX box will change color when it "learns" you TPS signal when you move the accelerator pedal.
nutts 96 ws6
09-02-2003, 08:43 AM
lt1 form,
Do you know where I can find instuctions on how to set it, or which color of wire it is for the tps. I've looked on zex and dint really find anything that specific.
lt1form
09-02-2003, 07:38 PM
Sorry , I asked my friend and he doesn't know where the instructions are at. I will ask him again and see if he can find them, check with www.zex.com and call thier 1-800 number on the website they are really nice and helpfull.
nutts 96 ws6
09-02-2003, 11:08 PM
lt1form,
Thanks for looking into it, but I found out that on my relay I had a couple wires mixed up and just switched them around. Works good now. Thanks again.
