ANY Thoughts?? on an 81 Z suspension
cwilgo63
07-01-2002, 09:38 PM
what do yall think about tha suspension and handling of an 81 Z28...also what can i do to make it better....other than poly front bushings.... are alum body mounts too harsh or will it end up handling better...it'll mainly be street and i do have subframe connectors too put it...i also wanna try to keep traction probs to a min. but have good acceleration.....also deos any1 know the backspacing needed to get p295/15R tiresor should i go with 17" or what????
thanks alot!!!!!!!!
angel71rs
07-02-2002, 11:24 PM
<font face="Verdana, Arial" size="2">Originally posted by cwilgo63:
thanks alot!!!!!!!!</font>
I have 295-50-15 Radial T/A's on my 71. 10" rim with 5" backspace. But it ended up rubbing on fender lip a little, so I rolled it up. If I had to do it over again, would try 10.5" bs to tuck in tires slightly.
texlurch
07-03-2002, 03:19 PM
Regardless of whether you want to corner or accelerate better, you need to remove all the rubber and slop from the suspension. They make poly subframe mounts, which are a little quieter than the aluminum. Neither are that bad on the street. I am replacing all the bushings front and rear with poly in my 70. For handling, I would go with the 17", for drag racing, the taller sidewall on a 15" would help out traction. I chose 17's for mine, 17 x 8 with 4" bs fit fine, you can go to a 9 or 11 inch on back if you do a little tweaking. I decided on the same size front and back, so I could rotate my tires
Texlurch - 68 Camaro (Just a little ol' LT1 with a Hot Cam, I SWEAR ;)
" a little spray never hurt anyone, spank you very much!"
or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?"
cwilgo63
07-03-2002, 04:09 PM
What do u mean quieter....do they squeak or what do u mean...also what about adjustable end links on a sway bar... plus how easy is it to bend the 17in rims...i have 400hp/th350/3.73 eaton posi..will p295/17 hold the roador should i just go with p295/50/15///also how high can u rev a stock short block/with balanced rods without spinning bearingsan tearing up the bottom end....the cam/heads/manifold/HEI are good through 6500rpm but will 6500 hurt the bottom end....thanks
